I setup an RPi4 about 2 weeks ago.
All was good until about yesterday.
I could no longer access HA.
I rebooted and nothing.
My router is showing the device active.
I can’t ping it.
I thought possibly the last plugin (Samba) may have caused a problem, so I wiped the installed and started from scratch.
Same issue: simply can’t access the device, ping or anything.
Hard wired setup, getting activity on the nic, router shows device exists (when powered on).
No, but it appears the router is still giving it the same IP based on the mac addr.
When I turn the device off, it drops off the router.
I did run a fing scan and neither the device nor IP addr show up.
Confused.
