I have a brand new raspberry pi 3 with the pi camera module. I am running HA using the official rpi2 docker image. It runs great on my system.
However, when I try to activate the rpi_camera module, I get an error when I start up HA. It says “file not found.” I have tried using the default directory, I have tried using the config directory. I have changed permissions to no avail.
Is there any explanation why the rpi_camera component cannot set up properly?
I figured out the error. The rpi_camera component uses the Linux killall command and for some reason this is not included in the official raspberry pi docker image. Either install killall or change the code to use pkill which fixed it for me.
Hey,
I’m trying to use home assistant with docker and i received a erro message:
bash-4.4# raspistill
Error relocating /opt/vc/lib/libvcos.so: backtrace_symbols: symbol not found
Error relocating /opt/vc/lib/libvcos.so: backtrace: symbol not found
Error relocating /opt/vc/lib/libvcos.so: mtrace: symbol not found
Could you help me with the install?
Do you have any tutorial or versions that you use (raspbian, docker-compose)?
You should REALLY stick to ONE thread. You are bouncing around reviving threads left and right for the same problem. I have answered you twice already and you haven’t responded.
Ok, Lets Go! Please, help me!
I did a clean install with the RASPBIAN STRETCH LITE - Release date:2018-04-18
I had install docker and docker composer, follow my docker-compose.yml
I Recieved this erro when i try to execute raspistill into the container:
If i execute out of container, on the raspbian, its works fine.
