Been struggling with this for over a month since my last rpi reinstall.
So I have a docker-compose stack:
hass:
hostname: hass
container_name: hass
restart: unless-stopped
image: homeassistant/raspberrypi3-homeassistant
ports:
- "8123:8123"
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
- /dev/ttyUSB1:/dev/ttyUSB1
- /dev/ttyACM0:/dev/ttyACM0
volumes:
- ${USERDIR}/docker/homeassistant:/config
- ${USERDIR}/docker/shared:/shared
- /etc/localtime:/etc/localtime:ro
- /var/run/docker.sock:/var/run/docker.sock:ro
network_mode: host
privileged: true
environment:
- PUID
- PGID
- TZ
labels:
- "traefik.enable=true"
- "traefik.frontend.rule=Host:hass.${DOMAINNAME}"
- "traefik.port=8123"
healthcheck:
test: ["CMD", "curl", "-f", "http://127.0.0.1:8123"]
interval: 30s
timeout: 10s
retries: 6
nodered-v8:
user: root
container_name: nodered-v8
hostname: nodered-v8
image: nodered/node-red-docker:rpi-v8
ports:
- 1888:1880
- 9288:9229
volumes:
- ${USERDIR}/docker/nodered-v8:/data
- /etc/timezone:/etc/timezone:ro
depends_on:
- mosquitto
# - mqtt-bridge
- hass
healthcheck:
test: ["CMD", "curl", "-f", "http://127.0.0.1:1888"]
interval: 30s
timeout: 10s
retries: 5
labels:
- "traefik.frontend.rule=Host:nodered-v8.${DOMAINNAME}"
- "traefik.frontend.entryPoints=http,https"
- "traefik.backend=nodered-v8"
- "traefik.port=1888"
- "com.centurylinklabs.watchtower.enable=true"
networks:
- traefik_proxy
I’ve tried countless of docker images, tags, what not… Every time, when I install the node-red-contrib-home-assistant-websocket I get errors when installing:
ReferenceError: nodeVersion is not defined
And after restarting I see:
2019-07-06T11:07:27.150000799Z 6 Jul 14:07:27 - [info] Installed module: node-red-contrib-home-assistant-websocket
2019-07-06T11:07:30.329841253Z 6 Jul 14:07:30 - [info] Added node types:
2019-07-06T11:07:30.330159999Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:server : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.331664044Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:server-events : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.331808262Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:server-state-changed : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.331852844Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:trigger-state : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.331888313Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:poll-state : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.331923364Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:api-call-service : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.331960395Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:ha-fire-event : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.331997114Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:api-current-state : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.344227600Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:ha-get-entities : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.344393900Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:api-get-history : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.344438639Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:api-render-template : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.344476764Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:ha-wait-until : SyntaxError: Unexpected token ...
2019-07-06T11:07:30.344512545Z 6 Jul 14:07:30 - [info] - node-red-contrib-home-assistant-websocket:ha-api : SyntaxError: Unexpected token ...
Please help
