baseboard: raspberry 3 b+
OS: Linux raspberrypi 4.19.108-v7+ #1298
#./configuration.yaml
default_config:
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yamllovelace:
mode: yamlbinary_sensor:
- platform: rpi_gpio
invert_logic: true
pull_mode: UP
bouncetime: 50
ports:
17: button
#ui-lovelace.yaml
title: home assistant
- title: Кнопка
icon: mdi:gesture-tap-button
cards:
- type: button
entity: binary_sensor.button
when you press the button repeatedly, the value hangs in the “on” state, while the “off” button.
if you run the code
#!/usr/bin/python3.7
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(pin, GPIO.IN)
try:
while True:
print(GPIO.input(17))
except KeyboardInterrupt:
pass
except:
print(“except”)
finally:
GPIO.cleanup()
here are no freezes
what am I doing wrong?
