When I tried to reset my pi for some changes this error appeared
Platform error switch.rpi_gpio - Integration ‘rpi_gpio’ not found.
My configuration.yaml is this
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
- platform: command_line
name: pi temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(1) }}'
scan_interval: 3
command: "curl https://server.duinocoin.com/balances/ferr_ari | jq '.result.balance'"
unit_of_measurement: 'Ducos'
unique_id: 'Duino_test'
value_template: "{{ value | round (3) }}"
switch:
- platform: rpi_gpio
ports:
18: RPI Cooling Fan
climate:
- platform: generic_thermostat
name: RPI Cooling Fan Controller
heater: switch.rpi_cooling_fan
target_sensor: sensor.cpu_temperature
min_temp: 55
max_temp: 80
ac_mode: true
target_temp: 55
cold_tolerance: 0.1
hot_tolerance: 0.1
min_cycle_duration:
seconds: 30
keep_alive:
minutes: 5
initial_hvac_mode: "cool"
homeassistant:
unit_system: metric
# etc
customize:
sensor.duino:
entity_picture: https://raw.githubusercontent.com/revoxhere/duino-coin/master/Resources/duco-alt.png
