i am running on a couple of RPI this docker container which is basically doing nothing else creating the below JSON endpoint
{"cpu_temperature":34.7,"cpu_current":7.87,"cpu_free":91.3,"cpu_average":{"totalIdle":2900011600,"totalTick":3333677700,"avgIdle":2900011600,"avgTotal":3333677700},"drive":{"totalGb":"7.0","usedGb":"2.6","freeGb":"4.1","usedPercentage":"37.1","freePercentage":"58.6"},"memory":{"totalMemMb":477.66,"usedMemMb":219.91,"freeMemMb":257.75,"freeMemPercentage":53.96},"network":{"docker0":{"interface":"docker0","inputBytes":0,"outputBytes":0},"eth0":{"interface":"eth0","inputBytes":109154810,"outputBytes":29028296},"lo":{"interface":"lo","inputBytes":13065452,"outputBytes":13065452}},"wifiStats":true}
I am using this code to create proper sensor on my HA instance
- platform: rest
resource: http://mysecreIP:9999/
timeout: 60
json_attributes:
- cpu_current
- cpu_free
- cpu_average
- cpu_temperature
- drive
- memory
- network
value_template: '{{ value_json.value}}'
headers:
Content-Type: application/json
User-Agent: Home Assistant Agent
and it work fine but i get the log spammed by
Template variable warning: 'dict object' has no attribute 'value' when rendering '{{ value_json.value}}'
I am very green on JSON so very likely I am doing something wrong here but can’t understand what.
Can someone help?
