RPI Hassio will not start up after boot (after Welcome prompt)
I have tried all fixes on here, including rebooting with new SD card etc etc and I still get the same messages.
One thing I have noticed is that after flashing the SD cards they loose all capacity. ie 64GB turns into a 32MB card! Am I missing something?
Oh I have tried that also with a pure delivery of SD-cards - It was broken when I got the card. I tried to use the SD formater software but that didn’t help me
I had the HA working perfect on the RPI4B and all was good till I tried to access via duckdns. Setup seemed to go ok but remote log in failed follow by local log in even using the dns.
Now as you have experienced nothing executes correctly and I cannot open HA. I can ping the IP, even changed the IP using nmcli and could ping that too but no luck with HA.
Thinking of buying a new RPI tomorrow and starting from scratch.
Hi all, hi @Alfonsolsl. Were you able to solve the issue?
I’m experiencing something similar.
Fresh hassOS install on
  • Pi4 4GB
  • Tried both hassOS 32 and 64 bit versions
  • Official Pi power supply
  • Sandisk A2 microSD card.
I tried for several hours. Still I cannot see the “Preparing home assistant” web UI, or any web UI at all. Browser says “connection refused”.
Anyone has a solution?
Thanks!
Hello, in my case was a faulty SD card after that I bought a samsung Pro micro sd endurance, and works very well, finally I decided to migrate to a external ssd and it’s amazing and cheap.
Thanks @Alfonsolsl. I tried with two SD actually.
Sandisk A2 64GB
And another 400GB Sandisk.
Same problem with both.
I will try with the one you suggest.
Thanks!
