I’d appreciate some ideas. If the HACLI I see IPV4 for end0 and IPV6, this address is handed out by my router and static assigned. With just this wired connection I cannot load lovelace - ping seems to work and the HA does seem to be able to communicate with my router and influxdb. I need to connect the wifi interface when both have a valid address I can load up the gui in my webbrowser but it is extremely slow - as if things don’t know where to send traffic. Any pointers or suggestions greatly appreciated. I’ve lost count of the times I’ve reinstalled from scratch using the RPI imager. I have changed out cables, using a reliable sd card. The HA observer on :4357 reports connected/supported/healthy. I can get to Settings->System->Logs but chrome finishes loading after a few seconds but the frame where the logs should appear remains blank for 10 seconds then just spins loading forever. I’m sure it’s some kind of network/ip/dns issue but can’t work out why both wired and wireless need to be assigned an ip address. I also have to insert a manual dns entry to point homeassistant.local at the wifi address. Pointing at the wired ip address does not work. Any suggestions or pointing in the right direction greatly appreciated. I’m no expert but I have tried everything I can think of.
