I would like to install an application to monitor the health of my Pi running HA (Hassbian). I have installed SSH and can access the HA instance on the Pi but cannot access the Pi command line in order to do the install. Is there a way to do this? Or is there a way to build a monitor within HA? Hope this isn’t a dumb question.
Can you elaborate on this? It isn’t making any sense to me.
When you are sshd into hassbian you are at the pi command line and you can install via apt. As usual you will need sudo.
However you shouldn’t need to install anything. https://www.home-assistant.io/components/systemmonitor/
Thank you for the response. Turns out it was a dumb question. I just found there is a system monitor available for HA. Please forgive. I’m new at this.
Thanks for this. Forgive my dumb question. I should have searched further before I posted.
No problem it takes a while to find your way around. There are 1300+ components in ha.
