I’m getting the following error in the home-assistant.log when i try to use rpi_rf
“homeassistant.bootstrap: Not initializing switch.rpi_rf because could not install dependency rpi-rf==0.9.5”
running HA 0.32.2
was able to install rpi-rf using “sudo pip3 install rpi-rf”
Any ideas??
here is the config i have in the configuration.yaml
****** configuration.yaml ***********
SOLVED: simply restarting the service doesn’t install the dependency. Had to actually run ‘hass’
I’m having the same issue, unable to install the dependency rpi-rf 0.9.6. Fairly new and clean install, update/upgrade reboot and all that. Can’t seem to get the rpi-rf component working.
