Getting the same issue as this:
but adding pi to gpio group or any other adduser command does not work. I’m running HASS in a docker container and HASS gives me the normal “try running as root!” error. What’s going on here?
Could I run this as a shell file and set to autostart at boot?
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/switch/rpi_rf.py”, line 73, in setup_platform
rfdevice.enable_tx()
File “/usr/local/lib/python3.6/site-packages/rpi_rf/rpi_rf.py”, line 77, in enable_tx
GPIO.setup(self.gpio, GPIO.OUT)
RuntimeError: No access to /dev/mem. Try running as root!
