That’s really a good device
Well, me too, I keep receiving a couple of codes every second, but that’s just because our houses are full of interferences unless you live in the middle of nowhere
So I got the new receiver today, soldered an antenna, connected it to 5V and there it is. Just working great! I simply use the mqtt sensor you implemented as triggers in automations to control devices. Couldn’t be much easier.
Thanks a lot for this add-on!
P.S. still get phantom reads while pushing the buttons on the remote but almost none otherwise
1398036 is switch off
1398033 is switch on
I also have one RF outdoor temperature sensor around that is sending data I can’t interpret right now.
eXtatic
Glad to hear it’s working fine.
I guess outdoor temperature sensors use a different code for every tenth of temperature degree, but I don’t really know how they work. Maybe it’s a standard protocol, who knows.
Bye the way I just received this antenna:
I’m not sure it will extend the reception range but it is cheap and it looks good. I’ll keep you updated.
the Addon wont Start.
Error is:
18-12-21 23:29:17 INFO (SyncWorker_14) [hassio.docker.addon] Start build local/armhf-addon-rfreceiver:1.0
18-12-21 23:29:17 ERROR (SyncWorker_14) [hassio.docker.addon] Can’t build local/armhf-addon-rfreceiver:1.0: 500 Server Error: Internal Server Error (“Cannot locate specified Dockerfile: Dockerfile”)
I thought I’d worked out some kinks, but then notice this is the Log File. Any idea why I get the message this can only be run on a Raspberry Pi? I am using a Pi 3 Model B. I tried both of the versions in the repository with the same results: RPi RF Receiver and RPi RF Receiver 3.
Using base prefix '/usr'
New python executable in /data/venv/bin/python3
Also creating executable in /data/venv/bin/python
Installing setuptools, pip, wheel...
done.
Running virtualenv with interpreter /usr/bin/python3
Collecting rpi-rf
Downloading https://files.pythonhosted.org/packages/e8/b4/092c00607f8e12670c0ac8cb9d4ec495952726105cc36c879825151630bf/rpi_rf-0.9.7-py3-none-any.whl
Collecting RPi.GPIO (from rpi-rf)
Downloading https://files.pythonhosted.org/packages/af/2f/407b6e4cc8a0bdf434825a160bba1807991886b63cce16a5f1a6e1f24cdf/RPi.GPIO-0.6.5.tar.gz
Building wheels for collected packages: RPi.GPIO
Running setup.py bdist_wheel for RPi.GPIO: started
Running setup.py bdist_wheel for RPi.GPIO: finished with status 'done'
Stored in directory: /root/.cache/pip/wheels/6d/fc/be/f0bd634b0033499def11c5c8b63731c3de443eed482dbe4c71
Successfully built RPi.GPIO
Installing collected packages: RPi.GPIO, rpi-rf
Successfully installed RPi.GPIO-0.6.5 rpi-rf-0.9.7
File "/share/rpi-rf_receive.py", line 15, in <module>
from rpi_rf import RFDevice
File "/data/venv/lib/python3.6/site-packages/rpi_rf/__init__.py", line 2, in <module>
from .rpi_rf import RFDevice
File "/data/venv/lib/python3.6/site-packages/rpi_rf/rpi_rf.py", line 9, in <module>
from RPi import GPIO
File "/data/venv/lib/python3.6/site-packages/RPi/GPIO/__init__.py", line 23, in <module>
from RPi._GPIO import *
**RuntimeError: This module can only be run on a Raspberry Pi!**
Hey guys,
I installed as describes, using almost known 433 MHz RX/TX Modul, but getting this message in log and don’t know what to do.
Successfully installed RPi.GPIO-0.6.5 rpi-rf-0.9.7 Traceback (most recent call last): File "/share/rpi-rf_receive.py", line 35, in <module> rfdevice.enable_rx() File "/data/venv/lib/python3.6/site-packages/rpi_rf/rpi_rf.py", line 189, in enable_rx GPIO.add_event_detect(self.gpio, GPIO.BOTH) RuntimeError: Failed to add edge detection
I already tried to change GPIO 27 to GPIO 22 with editing the rpi-rf_receive.py, but no win either.
May u can help?
Best regards,
Dominik
I would like to un-dig this topic. I am using Rpi 4 + 64bit and I stopped on error message while trying to install the addon:
21-03-15 21:55:53 ERROR (SyncWorker_4) [supervisor.docker.addon] Can't build local/aarch64-addon-rfreceiver:1.0: The command '/bin/ash -o pipefail -c apk add --no-cache py2-pip' returned a non-zero code: 1
21-03-15 21:55:53 ERROR (SyncWorker_4) [supervisor.docker.addon] Build log:
Step 1/29 : ARG BUILD_FROM
Step 2/29 : FROM $BUILD_FROM
---> 4412fd7c8229
Step 3/29 : ENV LANG C.UTF-8
---> Running in 931cf15ff4e2
Removing intermediate container 931cf15ff4e2
---> c18b56edab8c
Step 4/29 : RUN apk add --no-cache jq
---> Running in 3b926dabac84
fetch https://dl-cdn.alpinelinux.org/alpine/v3.13/main/aarch64/APKINDEX.tar.gz
fetch https://dl-cdn.alpinelinux.org/alpine/v3.13/community/aarch64/APKINDEX.tar.gz
OK: 28 MiB in 43 packages
Removing intermediate container 3b926dabac84
---> 8121856fc724
Step 5/29 : RUN apk add --no-cache py2-pip
---> Running in 4be47e3b03ec
ERROR: unable to select packages:
py2-pip (no such package):
required by: world[py2-pip]
Removing intermediate container 4be47e3b03ec
Any clues what can I improve?
