RPI3 Docker AppDaemon/HADashboard issues
Following this guideline for getting HADashboard running wiht Docker on a RPI 3
Getting this in the docker logs repeated over and over. Double check appdaemon.cfg , any ideas.
TypeError: int() argument must be a string, a bytes-like object or a number, not ‘NoneType’
/usr/bin/entry.sh: line 93: fg: job has terminated
File “/usr/local/bin/appdaemon”, line 11, in
load_entry_point(‘appdaemon===2.0.0beta3.5’, ‘console_scripts’, ‘appdaemon’)()
File “/usr/src/app/appdaemon/appdaemon.py”, line 1450, in main
conf.threads = int(config[‘AppDaemon’].get(‘threads’))
Terminated
Can you post that appdaemon.cfg?
Must admit I haven’t tried 3.5 yet
Here you go
my cfg file is in /home/pi/appdaemon_dashboard/appdaemon/conf
my docker build is
sudo docker create --name appdaemon_dashboard --restart always -p 5050:5050 -v /etc/localtime:/etc/localtime:ro -v /home/pi/appdaemon_dashboard/appdaemon/conf:/conf appdaemon_dashboard
appdaemon.cfg
[AppDaemon]
ha_url = https://xxxxx.duckdns.org
ha_key = xxxxxxxx
logfile = STDOUT
errorfile = STDERR
dash_url = http://192.168.7.xx:5050
app_dir = /home/pi/appdaemon_dashboard/appdaemon/conf/apps
dash_dir = /home/pi/appdaemon_dashboard/appdaemon/conf/dashboards
Apps
[hello_world]
module = hello
class = HelloWorld
app_dir and dash_dir are wrong as they are the paths on the host, not within the Docker container
I would omit them anyhow, as you still have them under conf. That is the default behavior and doesn’t need to be altered.
That did not seem to help. Took out both of those lines and restarted the container.
Is my docker build right. I get confused as to what the path of the conf needs to be
You need a threads entry in your [AppDaemon] section
Mine is
threads = 10
Duh, that was it, thanks for the help.
Good catch! Makes sense why it was an int error.
The build seems fine. You want to use /conf in the container, per your -v command, the stuff on the left is what it is on your host and the stuff on the right is that same location inside the container. So /conf/apps would be needed from the perspective of the inside
The Appdaemon startup inside Docker always points to /conf so you don’t need to override the behavior.
It’s revelant if you want to write apps that for some reason need to touch the file system, which wouldn’t be relevant for dashboards.
Thanks man! I am docker newbie so that helps.
