RPI3 model B and home assistant
I have problems with home assistant becoming unresponsive due to too much ram used on my RPI3 model B (1gb ram).
On regular use the ram usage is around 75% with swap on.
It happened a few times when updating home assistant (maybe a function emptying memory / closing services before the update process for older devices could help), but recently it started happening when updating the z-wave js addon too.
Restarting the RPI works every time and generally I can successfully update just after booting.
I’m waiting to upgrade to RPI 5 but in the mean time is there something that could be done on dev side to help older devices with that kind of problem?
