It’s stuck on “Preparing Home Assistant” Thank you very much for your time.
The log shows the following
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[01:05:21] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[01:05:22] INFO: Starting local supervisor watchdog...
23-01-02 01:05:28 INFO (MainThread) [__main__] Initializing Supervisor setup
23-01-02 01:05:28 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-01-02 01:05:28 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4-64
23-01-02 01:05:28 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2022.11.2
23-01-02 01:05:28 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-01-02 01:05:29 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-01-02 01:05:29 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-02 01:05:29 INFO (MainThread) [__main__] Setting up Supervisor
23-01-02 01:05:29 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-01-02 01:05:29 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-01-02 01:05:29 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-01-02 01:05:30 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-02 01:05:30 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-02 01:05:32 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-02 01:05:37 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-01-01 18:05:38 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-01-01 18:05:38 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2022.11.0'>]
23-01-01 18:05:38 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.11.0
23-01-01 18:05:39 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-01-01 18:06:08 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-01-01 18:06:08 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
23-01-01 18:06:08 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
23-01-01 18:06:08 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-01-01 18:06:19 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-01-01 18:06:19 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-01-01 18:06:19 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2022.07.0'>]
23-01-01 18:06:19 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0
23-01-01 18:06:19 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-01-01 18:06:27 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-01-01 18:06:27 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
23-01-01 18:06:27 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
23-01-01 18:06:32 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-01-01 18:06:42 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
23-01-01 18:06:42 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
23-01-01 18:06:42 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
23-01-01 18:06:42 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-01-01 18:06:55 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
23-01-01 18:06:55 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-01 18:07:03 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-01-01 18:07:03 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi4-64-homeassistant
23-01-01 18:07:03 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant found.
23-01-01 18:07:03 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
23-01-01 18:07:03 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-01-01 18:07:03 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-01-01 18:07:03 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-01-01 18:07:04 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
23-01-01 18:07:04 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.4 / BootSlot A
23-01-01 18:07:04 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-01-01 18:07:04 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-01-01 18:07:04 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-01-01 18:07:09 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Could not resolve host: github.com
23-01-01 18:07:09 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-01-01 18:07:09 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
23-01-01 18:07:09 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
23-01-01 18:07:10 INFO (MainThread) [supervisor.store] Loading add-ons from store: 44 all - 44 new - 0 remove
23-01-01 18:07:10 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-01-01 18:07:10 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-01-01 18:07:10 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-01-01 18:07:10 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-01-01 18:07:10 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-01-01 18:07:10 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-01 18:07:10 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-01-01 18:07:10 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-01 18:07:10 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-01-01 18:07:10 INFO (MainThread) [__main__] Running Supervisor
23-01-01 18:07:10 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-01-01 18:07:10 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor.txt
23-01-01 18:07:12 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-01-01 18:07:12 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2022.12.1
23-01-01 18:07:12 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2022.12.1.
23-01-01 18:13:28 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2022.12.1: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.1&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:13:28 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.SUPERVISOR / None
23-01-01 18:13:28 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2022.12.1: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.1&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:13:28 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
23-01-01 18:13:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-01-01 18:13:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-01-01 18:13:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-01-01 18:13:28 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-01-01 18:13:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-01-01 18:13:28 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-01-01 18:13:28 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-01-01 18:13:28 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-01-01 18:13:28 INFO (MainThread) [supervisor.host.info] Updating local host information
23-01-01 18:13:28 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:13:28 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
23-01-01 18:13:28 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-01-01 18:13:28 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-01-01 18:13:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-01-01 18:13:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-01-01 18:13:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-01-01 18:13:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-01-01 18:13:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-01-01 18:13:29 INFO (MainThread) [supervisor.host.services] Updating service information
23-01-01 18:13:29 INFO (MainThread) [supervisor.host.network] Updating local network information
23-01-01 18:13:29 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-01-01 18:13:29 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-01-01 18:13:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-01-01 18:13:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-01-01 18:13:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-01-01 18:13:30 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-01-01 18:13:30 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-01-01 18:13:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-01-01 18:13:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-01-01 18:13:31 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-01-01 18:13:31 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
23-01-01 18:19:34 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.8&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:19:34 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-01-01 18:20:04 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:20:04 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
23-01-01 18:25:40 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.8&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:25:40 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-01-01 18:26:10 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:26:10 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
23-01-01 18:31:47 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.8&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:31:47 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-01-01 18:32:17 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:32:17 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
23-01-01 18:37:52 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.8&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:37:52 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-01-01 18:38:22 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:38:22 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
23-01-01 18:43:59 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.8&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:43:59 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-01-01 18:44:29 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:44:29 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
23-01-01 18:50:05 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.8&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:50:05 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-01-01 18:50:35 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:50:35 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
23-01-01 18:56:11 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.12.8&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-01-01 18:56:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-01-01 18:56:41 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.12.8
23-01-01 18:56:41 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.12.8.
