RPi4 -> SSD stuck with waiting for the Home Assistant CLI to be ready
I ve copied from SD → SSD with etcher
if booting now from it will be stuck with waiting for the Home Assistant CLI to be ready
Now i’m back 4 the moment on SD, that works fine
Do a fresh install on SSD and restore from Backup. Its probably getting confused over file locations.
does not work here no addons are installed no SSH/Editor/Samba …
Crazy, all Add-Ons are gone, crap, much work todo.
Any Idea why?
also the mqtt Broker is gone.
I installed the mqtt broker again but it find not all my devices
need a little help maybe i forgot something?
i see on the device on the console
08:45:29.392 MQT: tele/Tassi67/STATE = {"Time":"2023-11-15T08:45:29","Uptime":"0T00:00:08","UptimeSec":8,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"RKsFritte","BSSId":"50:E6:36:3A:FA:00","Channel":6,"Mode":"11n","RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:03"}}
08:45:29.422 MQT: tele/Tassi67/SENSOR = {"Time":"2023-11-15T08:45:29","ENERGY":{"TotalStartTime":"2023-11-14T12:00:16","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":226,"Current":0.000}}
in HA in the Log
2023-11-15 08:45:25: New connection from 192.168.1.67:62381 on port 1883.
2023-11-15 08:45:25: New client connected from 192.168.1.67:62381 as DVES_0FE820 (p2, c1, k30, u'mqtt').
shouldn’t the device automatically appear under MQTT in the Devices Window?
Maybe an mistake in the MQTT Configuration?
