RS485 modbus timing issues
Have a couple of cheap SHT20 modbus humidity & temperature sensors attached to a USB<->RS485 adapter. Also have a couple of other modbus capable devices I wish to connect at a later date, including a PZEM-16 energy monitor.
My logs are being flooded with “No response from hub” errors, which appears to be a fairly common problem. Have tried a number of suggestions & tweaks, including delving in to the modbus code to insert waits between transactions. Have even resorted to adding a custom driver utilising the minimalmodbus python library.
During the course of testing with the minimalmodbus library, I noticed that errors were greatly reduced (or even disappeared) if a single thread application paused for some 150ms between reads. This got me thinking about the multi-threaded capabilities of HA… Looking at the error logs, it appears that each “modbus.sensor,name” runs under a different worker thread.
Question: Is it possible to force HA to run groups of modbus.sensors under a single worker thread ?
I also have some SHT20 sensors and was getting drop outs regularly using the modbus sensor component. Since later versions of HA broke this component, I was forced to find another way to use modbus. I ended up using the modbus add on in NodeRed, and haven’t had a single drop out since.
