Greetings to all
I’m new to HA and I’m configuring a 4-relay board, type RS485.
The action of closing or opening the relays I have already got it, placing these parameters in the “configuration.yaml” file:
command_state: rele 0-1-2-3
cover:
- platform: command_line
covers:
rele_1_bomba:
command_open: echo -en ‘\x01\x05\x00\x00\xFF\x00\x8C\x3A’ > /dev/ttyUSB0
command_close: echo -en ‘\x01\x05\x00\x00\x00\x00\xCD\xCA’ > /dev/ttyUSB0
command_state: rele2
rele_2_bomba:
command_open: echo -en ‘\x01\x05\x00\x01\xFF\x00\xDD\xFA’ > /dev/ttyUSB0
command_close: echo -en ‘\x01\x05\x00\x01\x00\x00\x9C\x0A’ > /dev/ttyUSB0
command_state: rele3
rele_3_bomba:
command_open: echo -en ‘\x01\x05\x00\x02\xFF\x00\x2D\xFA’ > /dev/ttyUSB0
command_close: echo -en ‘\x01\x05\x00\x02\x00\x00\x6C\x0A’ > /dev/ttyUSB0
command_state: rele4
rele_4_bomba:
command_open: echo -en ‘\x01\x05\x00\x03\xFF\x00\x7C\x3A’ > /dev/ttyUSB0
command_close: echo -en ‘\x01\x05\x00\x03\x00\x00\x3D\xCA’ > /dev/ttyUSB0
End RS485
As you can see, the relay board changes status by sending a predefined code in Hexadecimal. I also have the option to ask the board the status of each relay, but I could only do it via console, sending a hexadecimal code and receiving another code indicating the status of the relays.
for example:
-If I have all the relays open and I send the status 0101000001FDCA the result will be a Hex code with the format xx-xx-xx-xx-xx-00-xx-xx
-If I only have active the relay number 0. and then I send the status the result will be: xx-xx-xx-xx-xx-01-xx-xx and so on until reaching 0F where it indicates that all the relays are active.
Can you tell me how I can make the HA appear or show the possible status of the relays?
The ideal is to send every certain interval the status code to check the state of the relays.
Thank you
