Doing my Delta Solivia Inverter ESPHome modbus integration, I experienced a really strange issue with the actual RS485 module hardware.
I have two different versions ‘on stock’ of the visually, completely identical ttl (3,3v/5v) to rs485 module.The Dollatek version (marked with RS485 to TTL on the pcb) bought on Amazon and the ‘no name’ version (marked with XY-017 on the pcb) bought on AliExpress.
The Dollatek version works perfectly with all my connected hardware, Schneider iEM3155 Energy Meter, Delta inverter & Nilan air vent system. But the XY-017 version somehow shorts/overloads the esp8266 when I use it with the Delta Inverter. Perhaps the XY-017 version draws a bit more power than the other version (3,3v feeded from the esp8266 pin) ? Everything works flawlessly with the other device type ? I thought that I might just experience one erroneous device. But no, I tried three devices and none of them worked with the inverter. But all three worked with my Energy Meter ?
Devices looks completely identical, populated components also seems to be identical. But apparently there’s a difference somewhere. Could anyone explain or have experienced similar ?
If not, let this be a gentle warning to exercise caution when choosing RS485 modules.
No name version - Marked XY-017 on the pcb backside:
Dollatek version - Marked RS485 to TTL on the pcb backside:
Regards
Henning
