I would like to have some newsfeed on my home screen, so I first added the sample configuration https://home-assistant.io/components/feedreader/
Unfortunately, nothing shows up. Do I have to change more ?
Besides that : Is it possible to update the newsfeed more often than once in an hour ?
You will not get a newsfeed in the UI with this component. It only gives Home Assistant Events when there is a new item in the feed. You will need an automation to do something with this event. Check out the example in the docs.
no I dont want to use it, but I managed to install the list-card and feedparser without it. Got it working also, but I cant get the description tag to show up. Only title works even tho I can see the description in the sensor
card:
type: entities
type: 'custom:list-card'
entity: sensor.rss_engadget
title: Engadget
feed_attribute: entries
columns:
- title: ''
add_link: link
field: title
I would want two columns like this, but the code below breaks it all, however if I insert image or title it shows 2 columns:
Hi all,
I’m trying to do basically the same (display 2 columns from rss feed) and for me the same issue occures as seen from Mattie.
Any Updates or fixes on that?
