Can anyone shed some light on this… I’m using the rtl_433 add-on. When started, it gives the following messages:
[21:52:59] INFO: The mqtt addon is not available.
[21:52:59] INFO: Manually update the output line in the configuration file with mqtt connection settings, and restart the addon.
[21:52:59] WARNING: rtl_433 now supports automatic configuration and multiple radios. The rtl_433_conf_file option is deprecated. See the documentation for migration instructions
The first line is ok, I have an external mqtt broker. The second line says to add the mqtt broker to the config, that’s also ok. Then the 3rd line says that the config is deprecated… It refers to migration instructions
but I haven’t been able to find any.
