Rtl_433 - broker data
Data from a weatherstation (Bresser 6 in1) arrives the broker in my Home-assistant. ( adres: home/rtl433)
MQTT let me know how that the data is correct.
In Hassio-mqtt can i see that the data arrives in json format when i listen.
I can see: home/rtl433
{ “time”: “2024-03-25 11:56:11”, “model”: “Bresser-6in1”, “id”: 426774881, “channel”: 0, “battery_ok”: 0,
“temperature_C”: 10.6, “humidity”: 69, “sensor_type”: 1, “wind_max_m_s”: 2.1, “wind_avg_m_s”: 1.8, “wind_dir_deg”: 202,
“uv”: 0, “startup”: 1, “flags”: 0, “mic”: “CRC”}
How can i see this sensordata e.g model, temperature_C , humidity , on the hassio/locvelace dahsboard.
Info from inet e.g.
https://www.vromans.org/johan/articles/hass_bresser51/index.html
and many other pages)
brings me not a SOLUTION.
Who helps?
Dick
