RTL 433 cannot read config file HA
hi,
i have installed the rtl 433 HA add on, but service cannot read the config file to switch the frequency, on that PI with PI OS the SDR dongle is working properly with rtl 433.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[18:50:37] WARNING: rtl_433 now supports automatic configuration and multiple radios. The rtl_433_conf_file option is deprecated. See the documentation for migration instructions.
Starting rtl_433 -c /config/rtl_433.conf
rtl_433 version 21.12-101-g9eec4611 branch  at 202204282249 inputs file rtl_tcp RTL-SDR
Use -h for usage help and see https://triq.org/ for documentation.
Failed to stat "/config/rtl_433.conf"
Registered 186 out of 218 device decoding protocols [ 1-4 8 11-12 15-17 19-23 25-26 29-36 38-60 63 67-71 73-100 102-105 108-116 119 121 124-128 130-149 151-161 163-168 170-175 177-197 199 201-215 217-218 ]
Found Fitipower FC0012 tuner
Exact sample rate is: 250000.000414 Hz
Sample rate set to 250000 S/s.
Tuner gain set to Auto.
Tuned to 433.920MHz.
Allocating 15 zero-copy buffers
baseband_demod_FM: low pass filter for 250000 Hz at cutoff 25000 Hz, 40.0 us
config file:
# output mqtt://${host}:${port},user=${username},pass=${password},retain=${retain}
frequency 868.272M
thx for your help, BLOZZY
It list this message in your logs.
Any updates on this?
Does this mean you need no rtl_433.conf file whatsoever? It did create a template conf file on installation however.
