RTL 433 (Custom) Component - Dead Frontend
Hi all,
I just started to write my very first component. It is based on / ripped off the MQTT component and should do the following:
  • Run rtl_433 (https://github.com/merbanan/rtl_433) in the background (subprocess), emitting JSON for every sensor read which was previously subscribed for (by channel / model / id) - channel / model / id are equivalent to “state_topic” used by the MQTT component
  • Provide a sensor platform which registers at the component with channel / model / id and reading the JSON emitted with a value_template (like the MQTT sensor)
The good news: The component and the sensor do work. They are not really finished, but they work as prove of concept. I can see the component starting, the subprocess is started and the sensor is updated (all seen in the hass-log).
The bad news: activating the component in configuration.yaml (see code below) kills the frontend. It is not working any more, I get connection errors trying to connect via web browser and the weirdest part: There is not a singe error or warning in the log which would explain why the frontend fails to start.
What could be going wrong?
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: xxx
  longitude: xxx
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: xxx
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Europe/Berlin
  customize: !include /home/pi/repositories/homeassistant/customize.yaml
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  api_password: xxx
# Checks for available updates
updater:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
logger:
  default: info
  logs:
    homeassistant.components.device_tracker.fritz: warn
    homeassistant.components.camera: warn
    homeassistant.components.http: warn
    custom_components.rtl433: debug
recorder:
  db_url: postgres://@/homeassistant
# Text to speech
tts:
  platform: google
# The MQTT broker to use
mqtt:
  broker: xxx
  port: 1883
  client_id: home-assistant
  username: xxx
  password: xxx
# This is the section that kills the frontend -> enabling my custom component
rtl433:
  hop_interval: 60
  rtl_path: '/usr/local/bin/rtl_433'
  protocols:
    - 25
    - 03
media_player:
  - platform: yamaha
    host: xxx
    source_names:
      HDMI1: "TV"
      HDMI2: "XBox"
      HDMI3: "WII U"
    source_ignore:
      - "AV1"
      - "AV2"
      - "AV3"
      - "AV4"
      - "AV5"
      - "AV6"
      - "HDMI4"
      - "TUNER"
telegram_bot:
  - platform: broadcast
    api_key: xxx
    allowed_chat_ids:
      - xxx
automation: !include_dir_merge_list /home/pi/repositories/homeassistant/automation/
group: !include /home/pi/repositories/homeassistant/groups.yaml
zone: !include /home/pi/repositories/homeassistant/zones.yaml
device_tracker: !include /home/pi/repositories/homeassistant/device_tracker.yaml
sensor: !include_dir_merge_list /home/pi/repositories/homeassistant/sensor
binary_sensor: !include_dir_merge_list /home/pi/repositories/homeassistant/binary_sensor
switch: !include_dir_merge_list /home/pi/repositories/homeassistant/switch
notify: !include_dir_merge_list /home/pi/repositories/homeassistant/notify
alert: !include_dir_merge_named /home/pi/repositories/homeassistant/alert
So, I can’t say why it doesn’t work, but I would suggest you try a shell script like this:
/usr/local/bin/rtl_433 -f 345000000 -F json -R 70 -U | while read line
do
  echo $line | /usr/bin/mosquitto_pub -h $MQTT_HOST -u $MQTT_USER -P $MQTT_PASS -i RTL_433 -r -l -t
done
That will forward anything it finds to the MQTT server you specify, and then you can pull it like any other MQTT thing (sensor, binary_sensor, etc).
I had this working already but absolutely wanted to build a component :-/
