RTL_433 no longer work since new Homeassistant-Core "core_2024.10.4"
Hello everyone
With the addon “rtl_433” I read my weatherstation and send the info with the addon “rtl_433 MQTT” to addon "mosquitto broker). The entities I use in the dashboard etc…
Now my problem:
With Homeassistant-Core “core_2024.9.0” the add-ons “rtl_433 Home Assistant Add-on 0.5.2” and “rtl_433 MQTT Auto Discovery Home Assistant Add-on 0.8.2” still work perfectly.
Only after an update to HA-Core “core_2024.10.4” or “core_2024.11.0” does rtl_433 unfortunately no longer work.
The following message appear in the LOG file:
Could you please take a look at this?
I believe that several more people have this problem
Thank you very much
it looked like i am experiencing a similiar problem.
the 433 addon did not detect any sensors anymore.
in the protocol no detected devices show and mqtt is not populated.
after i disabled my config file it started working → i just had to correct the path to the file and now it is fine again :wink:
Hello.
My problem has been solved.
I had a malfunction on mqtt, which was caused by a battery of a sensor that was not yet empty.
Now I just have to make my settings and everything should be fine.
best regards
william
