TL;DR data is received but not forwarded to home assistant.
To preface the whole thing, nothing about the configuration or setup was changed. The only possible change was an update to the OS or core or something.
rtl_433 stopped updating my accurite outdoor temperature sensor. At first I thought that the batteries died and I put in some new ones, no change. Then I thought the SDR died. I have a second one and after changing it out, no change. Then I thought the sensor died. I then used the second SDR to sniff and I can see the acurite transmissions.
rtl_433 seems to start up ok with the following log.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[16:48:43] WARNING: rtl_433 now supports automatic configuration and multiple radios. The rtl_433_conf_file option is deprecated. See the documentation for migration instructions.
Starting rtl_433 -c /config/rtl_433/rtl_433.conf
rtl_433 version 21.12-101-g9eec4611 branch at 202204282249 inputs file rtl_tcp RTL-SDR
Use -h for usage help and see https://triq.org/ for documentation.
Publishing MQTT data to 192.168.0.4 port 1883
Publishing device info to MQTT topic "rtl_433/9b13b3f4-rtl433/devices[/type][/model][/subtype][/channel][/id]".
Publishing events info to MQTT topic "rtl_433/9b13b3f4-rtl433/events".
Publishing states info to MQTT topic "rtl_433/9b13b3f4-rtl433/states".
Registered 4 out of 218 device decoding protocols [ 40 91 73 192 ]
Found Rafael Micro R820T tuner
Exact sample rate is: 250000.000414 Hz
[R82XX] PLL not locked!
Sample rate set to 250000 S/s.
Tuner gain set to Auto.
Tuned to 433.920MHz.
Allocating 15 zero-copy buffers
MQTT Connected...
MQTT Connection established.
rtl_433 is at least partially working. I have some Govee 433 water leak sensors and I can trigger a water leak warning that sends a push notification to my phone. Also the rtl_433 log eventually (don’t know why this is but after like 2 days) starts to spit up received information. It clearly sees the acurite transmissions. It also see other ones that are in range and they don’t update either.
The time not changing is an artifact. The messages are flying so fast that I can only capture a small section. Why there are 3 messages at a time I don’t know but here are two other captures from today. The time on them is different.
Not sure how the this is related. I turned the Acurite sensor to channel B. It didn’t seem to show up in MQTT. The Auto discovery should have taken care of that. I switched the auto discovery to debug level log and rebooted it. The B sensor showed up. Switched the sensor back to A and it works now.
The other two devices that are in range also started working.
I have several 433MHz sensors. They have been working for months without issues.
However, since yesterday all sensor readings are stuck. No updates coming
MQTT exprorer does not show any updates.
However, the SDR dongle works on laptop normally.
I have resetted everything, taken an older backup, changes the USB port…etc
Blockquote
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
Starting rtl_433 with rtl_433.conf…
[rtl_433] rtl_433 version 22.11 branch at 202211191645 inputs file rtl_tcp RTL-SDR
[rtl_433] Use -h for usage help and see https://triq.org/ for documentation.
[rtl_433] Publishing MQTT data to core-mosquitto port 1883
[rtl_433] Publishing events info to MQTT topic “rtl_433[/model][/id]”.
[rtl_433] Registered 176 out of 223 device decoding protocols [ 1-4 8 11-12 15-17 19-23 25-26 29-36 38-58 63 67-71 73-81 83-87 91-94 96-100 102-105 108-109 111-116 119 121 124-128 130-139 141-149 151-155 157-161 163-167 170-175 177-179 181-185 187-197 199 202 204-215 217-223 ]
[rtl_433] Detached kernel driver
[rtl_433] Found Fitipower FC0013 tuner
[rtl_433] Exact sample rate is: 250000.000414 Hz
[rtl_433] Sample rate set to 250000 S/s.
[rtl_433] Tuner gain set to Auto.
[rtl_433] Tuned to 433.920MHz.
[rtl_433] Allocating 15 zero-copy buffers
[rtl_433] baseband_demod_FM: low pass filter for 250000 Hz at cutoff 25000 Hz, 40.0 us
[rtl_433] MQTT Connected…
[rtl_433] MQTT Connection established.
The crystal on those sticks is really temperature sensitive and that affects the frequency its listening to.
So if your gear near the stick increase the surrounding air a degree then it might affect the reception.
You can’t just move it and test it.
You need to let it run for a longer period, becausenthe temperature need to settle and you need to see it in all conditions.
