Hello everyone.
Given HAOS running on PI4. Everything working fine:
Home Assistant 2023.9.0
Supervisor 2023.09.2
Operating System 10.5
Frontend 20230906.1 - latest
Installed RTL_433 repository from GitHub - pbkhrv/rtl_433-hass-addons: Collection of Home Assistant add-ons that use rtl_433
Installed RTL_433 add-on, rebooted the system. Everything comes back online, no errors in the supervisor log.
RTL_433 starts and this is the log output
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
Starting rtl_433 with rtl_433.conf...
[rtl_433] rtl_433 version 22.11 branch at 202211191645 inputs file rtl_tcp RTL-SDR
[rtl_433] Use -h for usage help and see https://triq.org/ for documentation.
[rtl_433] Publishing MQTT data to core-mosquitto port 1883
[rtl_433] Publishing device info to MQTT topic "rtl_433/9b13b3f4-rtl433/devices[/type][/model][/subtype][/channel][/id]".
[rtl_433] Publishing events info to MQTT topic "rtl_433/9b13b3f4-rtl433/events".
[rtl_433] Publishing states info to MQTT topic "rtl_433/9b13b3f4-rtl433/states".
[rtl_433] Registered 176 out of 223 device decoding protocols [ 1-4 8 11-12 15-17 19-23 25-26 29-36 38-58 63 67-71 73-81 83-87 91-94 96-100 102-105 108-109 111-116 119 121 124-128 130-139 141-149 151-155 157-161 163-167 170-175 177-179 181-185 187-197 199 202 204-215 217-223 ]
[rtl_433] Detached kernel driver
[rtl_433] Found Rafael Micro R820T tuner
[rtl_433] Exact sample rate is: 250000.000414 Hz
[rtl_433] [R82XX] PLL not locked!
[rtl_433] Sample rate set to 250000 S/s.
[rtl_433] Tuner gain set to Auto.
[rtl_433] Tuned to 433.920MHz.
[rtl_433] Allocating 15 zero-copy buffers
[rtl_433] baseband_demod_FM: low pass filter for 250000 Hz at cutoff 25000 Hz, 40.0 us
[rtl_433] MQTT Connected...
[rtl_433] MQTT Connection established.
There is one file rtl_433.conf.template
created at /config/rtl_433/
directory with following content:
# This is an empty template for configuring rtl_433. mqtt information will be
# automatically added. Create multiple files ending in '.conf.template' to
# manage multiple rtl_433 radios, being sure to set the 'device' setting. The
# device must be set before mqtt output lines.
# https://github.com/merbanan/rtl_433/blob/07368e73c6a6d71919e6a98a57116324cbc3b952/conf/rtl_433.example.conf
output mqtt://${host}:${port},user=${username},pass=${password},retain=${retain}
report_meta time:iso:usec:tz
# To keep the same topics when switching between the normal and edge versions,
# use this output line instead.
# output mqtt://${host}:${port},user=${username},pass=${password},retain=${retain},devices=rtl_433/9b13b3f4-rtl433/devices[/type][/model][/subtype][/channel][/id],events=rtl_433/9b13b3f4-rtl433/events,states=rtl_433/9b13b3f4-rtl433/states
# Uncomment the following line to also enable the default "table" output to the
# addon logs.
# output kv
# Disable TPMS sensors by default. These can cause an overwhelming number of
# devices and entities to show up in Home Assistant.
# This list is generated by running:
# rtl_433 -R help 2>&1 | grep -i tpms | sd '.*\[(\d+)\].*' 'protocol -/run.sh'
# [59] Steelmate TPMS
# [60] Schrader TPMS
# [82] Citroen TPMS
# [88] Toyota TPMS
# [89] Ford TPMS
# [90] Renault TPMS
# [95] Schrader TPMS EG53MA4, PA66GF35
# [110] PMV-107J (Toyota) TPMS
# [123]* Jansite TPMS Model TY02S
# [140] Elantra2012 TPMS
# [156] Abarth 124 Spider TPMS
# [168] Schrader TPMS SMD3MA4 (Subaru)
# [180] Jansite TPMS Model Solar
# [186] Hyundai TPMS (VDO)
# [201] Unbranded SolarTPMS for trucks
# [203] Porsche Boxster/Cayman TPMS
protocol -59
protocol -60
protocol -82
protocol -88
protocol -89
protocol -90
protocol -95
protocol -110
protocol -123
protocol -140
protocol -156
protocol -168
protocol -180
protocol -186
protocol -201
protocol -203
Now, when I add a single line
protocol 245
Add-on stops loading and throws an error. It does not load if I enable any protocol above 223.
The fact that it does not allow any protocol above 223 is hintend by the log entry from the default config:
How do I make protocols above 223 work?
I have ThermoPro TX-2C sensors that need (according to the documentation’s sample config file) the protocol 245
Sample file, line 474
