I have a Kenik KG-5214UVR CCTV DVR recorder and I want to add RTSP stream to my HA.
In configuration of my DVR I found a RTSP setting as:
rtsp://[IP]:[PORT]/mode=real&idc=[]&ids=[]
where idc is a channel and ids is a set of primary or secondary stream
I can successfully connect to this stream via VLC using this adress:
rtsp://ha:[email protected]:554/mode=real&idc=1&ids=1
Configuration of HA is:
camera:
- platform: generic
stream_source: "rtsp://ha:[email protected]:554/mode=real&idc=1&ids=1"
Error figured in HA log:
Logger: homeassistant.components.stream.stream.camera.my_camera
Source: components/stream/__init__.py:340
Integration: Stream ([documentation](https://www.home-assistant.io/integrations/stream), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+stream%22))
First occurred: 22:38:02 (3 occurrences)
Last logged: 22:38:33
Error from stream worker: Error opening stream (HTTP_BAD_REQUEST, Server returned 400 Bad Request) rtsp://****:****@192.168.0.223:554/mode=real&idc=1&ids=1
What I’m doing wrong?
