I can’t provide a demo since the camera is in LAN which can’t be access from the world. but camera IPC-HDW3233C (from dahua) web page is using rtspoverwebsocket, it’s quite smooth, much faster than the one from home assistant. maybe home assistant will consider using this feature in frontend
https://www.dahuatech.com/product/info/4273.html
var WebsocketServer = function(a, b) {
function c() {}
function d(a, b, c, d) {
var e = "";
switch (a) {
case "OPTIONS":
case "TEARDOWN":
case "GET_PARAMETER":
case "SET_PARAMETERS":
e = a + " " + M + " RTSP/1.0\r\nCSeq: " + B + "\r\n" + z + "\r\n";
break;
case "DESCRIBE":
break;
case "SETUP":
debug.log("trackID: " + b),
e = a + " " + M + "/trackID=" + b + " RTSP/1.0\r\nCSeq: " + B + "\r\n" + z + "Transport: DH/AVP/TCP;unicast;interleaved=" + 2 * b + "-" + (2 * b + 1) + "\r\n",
e += 0 != G ? "Session: " + G + "\r\n\r\n" : "\r\n";
break;
case "PLAY":
e = a + " " + M + " RTSP/1.0\r\nCSeq: " + B + "\r\nSession: " + G + "\r\n",
void 0 != d && 0 != d ? (e += "Range: npt=" + d + "-\r\n",
e += z + "\r\n") : e += z + "\r\n";
break;
case "PAUSE":
e = a + " " + M + " RTSP/1.0\r\nCSeq: " + B + "\r\nSession: " + G + "\r\n\r\n";
break;
case "SCALE":
e = "PLAY " + M + " RTSP/1.0\r\nCSeq: " + B + "\r\nSession: " + G + "\r\n",
e += "Scale: " + d + "\r\n",
e += z + "\r\n"
return debug.log(e),
e
function e(a) {
debug.log(a);
var b = {}
, e = a.search("CSeq: ") + 5;
if (B = parseInt(a.slice(e, e + 10)) + 1,
b = m(a),
b.ResponseCode === x.UNAUTHORIZED && "" === z)
f(b);
else if (b.ResponseCode === x.OK) {
if ("Options" === E)
return E = "Describe",
d("DESCRIBE", null, null);
if ("Describe" === E) {
I = !1,
D = n(a),
"undefined" != typeof b.ContentBase && (D.ContentBase = b.ContentBase);
var g = 0;
for (g = 0; g < D.Sessions.length; g += 1) {
var i = {};
"JPEG" === D.Sessions[g].CodecMime || "H264" === D.Sessions[g].CodecMime || "H265" === D.Sessions[g].CodecMime || "H264-SVC" == D.Sessions[g].CodecMime ? (i.codecName = D.Sessions[g].CodecMime,
"H264-SVC" == D.Sessions[g].CodecMime && (i.codecName = "H264"),
"H265" == D.Sessions[g].CodecMime && c.prototype.setLiveMode("canvas"),
i.trackID = D.Sessions[g].ControlURL,
i.ClockFreq = D.Sessions[g].ClockFreq,
i.Port = parseInt(D.Sessions[g].Port),
"undefined" != typeof D.Sessions[g].Framerate && (i.Framerate = parseInt(D.Sessions[g].Framerate),
w.setFPS(i.Framerate),
N(i.Framerate)),
A.push(i)) : "PCMU" === D.Sessions[g].CodecMime || -1 !== D.Sessions[g].CodecMime.search("G726-16") || -1 !== D.Sessions[g].CodecMime.search("G726-24") || -1 !== D.Sessions[g].CodecMime.search("G726-32") || -1 !== D.Sessions[g].CodecMime.search("G726-40") || "PCMA" === D.Sessions[g].CodecMime ? ("PCMU" === D.Sessions[g].CodecMime ? i.codecName = "G.711Mu" : "G726-16" === D.Sessions[g].CodecMime ? i.codecName = "G.726-16" : "G726-24" === D.Sessions[g].CodecMime ? i.codecName = "G.726-24" : "G726-32" === D.Sessions[g].CodecMime ? i.codecName = "G.726-32" : "G726-40" === D.Sessions[g].CodecMime ? i.codecName = "G.726-40" : "PCMA" === D.Sessions[g].CodecMime && (i.codecName = "G.711A"),
i.Bitrate = parseInt(D.Sessions[g].Bitrate),
A.push(i)) : "mpeg4-generic" === D.Sessions[g].CodecMime || "MPEG4-GENERIC" === D.Sessions[g].CodecMime ? (i.codecName = "mpeg4-generic",
A.push(i)) : "vnd.onvif.metadata" === D.Sessions[g].CodecMime ? (i.codecName = "MetaData",
A.push(i)) : "stream-assist-frame" === D.Sessions[g].CodecMime ? (i.codecName = "stream-assist-frame",
A.push(i)) : debug.log("Unknown codec type:", D.Sessions[g].CodecMime, D.Sessions[g].ControlURL)
return F = 0,
E = "Setup",
debug.log(A),
d("SETUP", F)
if ("Setup" === E) {
if (G = b.SessionID,
F < A.length)
return A[F].RtpInterlevedID = b.RtpInterlevedID,
A[F].RtcpInterlevedID = b.RtcpInterlevedID,
F += 1,
F !== A.length ? d("SETUP", A[F].trackID.split("=")[1] - 0) : (w.sendSdpInfo(A, L, I),
E = "Play",
d("PLAY", null));
debug.log("Unknown setup SDP index")
} else if ("Play" === E) {
G = b.SessionID,
clearInterval(J),
J = setInterval(function() {
return h(d("GET_PARAMETER", null, null))
}, y);
E = "Playing"
} else
"Playing" === E || debug.log("unknown rtsp state:" + E)
} else if (b.ResponseCode === x.NOTSERVICE) {
if ("Setup" === E && -1 !== A[F].trackID.search("trackID=t"))
return A[F].RtpInterlevedID = -1,
A[F].RtcpInterlevedID = -1,
F += 1,
I = !1,
C({
errorCode: "504",
description: "Talk Service Unavilable",
place: "RtspClient.js"
F < A.length ? d("SETUP", A[F].trackID) : (E = "Play",
d("PLAY", null));
C({
errorCode: "503",
description: "Service Unavilable"
} else if (b.ResponseCode === x.NOTFOUND) {
if ("Describe" === E || "Options" === E)
return void C({
errorCode: 404,
description: "rtsp not found"
} else if (b.ResponseCode === x.INVALID_RANGE)
return ("backup" === H || "playback" === H) && C({
errorCode: "457",
description: "Invalid range"
void debug.log("RTP disconnection detect!!!")
function f(a) {
var b = O.username
, c = O.passWord
, e = {
Method: null,
Realm: null,
Nonce: null,
Uri: null
, f = null;
e = {
Method: E.toUpperCase(),
Realm: a.Realm,
Nonce: a.Nonce,
Uri: M
f = g(b, c, e.Uri, e.Realm, e.Nonce, e.Method),
z = 'Authorization: Digest username="' + b + '", realm="' + e.Realm + '",',
z += ' nonce="' + e.Nonce + '", uri="' + e.Uri + '", response="' + f + '"',
z += "\r\n",
h(d("OPTIONS", null, null))
function g(a, b, c, d, e, f) {
var g = null
, h = null
, i = null;
return g = hex_md5(a + ":" + d + ":" + b).toLowerCase(),
h = hex_md5(f + ":" + c).toLowerCase(),
i = hex_md5(g + ":" + e + ":" + h).toLowerCase()
function h(a) {
if (void 0 != a && null != a && "" != a)
if (null !== o && o.readyState === WebSocket.OPEN) {
if (v === !1) {
var b = a.search("DESCRIBE");
-1 !== b && (u = !0,
v = !0)
void 0 != a && o.send(i(a))
} else
debug.log("ws未连接")
function i(a) {
for (var b = a.length, c = new Uint8Array(new ArrayBuffer(b)), d = 0; b > d; d++)
c[d] = a.charCodeAt(d);
return c
function j(a) {
var b = new Uint8Array
, c = new Uint8Array(a.data);
for (b = new Uint8Array(c.length),
b.set(c, 0),
s = b.length; s > 0; )
if (36 !== b[0]) {
var d = String.fromCharCode.apply(null, b)
, f = null;
-1 !== d.indexOf("OffLine:File Over"),
u === !0 ? (f = d.lastIndexOf("\r\n"),
u = !1) : f = d.search("\r\n\r\n");
var g = d.search("RTSP");
if (-1 === g)
return void (b = new Uint8Array);
if (-1 === f)
return void (s = b.length);
q = b.subarray(g, f + p),
b = b.subarray(f + p);
var i = String.fromCharCode.apply(null, q);
h(e(i)),
s = b.length
} else {
if (r = b.subarray(0, p),
t = r[2] << 24 | r[3] << 16 | r[4] << 8 | r[5],
!(t + p <= b.length))
var j = b.subarray(p, t + p);
l(r, j),
b = b.subarray(t + p),
s = b.length
function k(a) {
K = a
function l(a, b) {
w.parseRTPData(a, b),
k(!0)
function m(a) {
var b = {}
, c = 0
, d = 0
, e = null
, f = null
, g = null;
if (-1 !== a.search("Content-Type: application/sdp")) {
var h = a.split("\r\n\r\n");
g = h[0]
} else
g = a;
var i = g.split("\r\n")
, j = i[0].split(" ");
if (j.length > 2 && (b.ResponseCode = parseInt(j[1]),
b.ResponseMessage = j[2]),
for (c = 1; c < i.length; c++)
if (f = i[c].split(":"),
"Public" === f[0])
b.MethodsSupported = f[1].split(",");
else if ("CSeq" === f[0])
b.CSeq = parseInt(f[1]);
else if ("Content-Type" === f[0])
b.ContentType = f[1],
-1 !== b.ContentType.search("application/sdp") && (b.SDPData = n(a));
else if ("Content-Length" === f[0])
b.ContentLength = parseInt(f[1]);
else if ("Content-Base" === f[0]) {
var k = i[c].search("Content-Base:");
-1 !== k && (b.ContentBase = i[c].substr(k + 13))
} else if ("Session" === f[0]) {
var l = f[1].split(";");
b.SessionID = parseInt(l[0])
} else if ("Transport" === f[0]) {
var m = f[1].split(";");
for (d = 0; d < m.length; d++) {
var o = m[d].search("interleaved=");
if (-1 !== o) {
var p = m[d].substr(o + 12)
, q = p.split("-");
q.length > 1 && (b.RtpInterlevedID = parseInt(q[0]),
b.RtcpInterlevedID = parseInt(q[1]))
} else if ("RTP-Info" === f[0]) {
f[1] = i[c].substr(9);
var r = f[1].split(",");
for (b.RTPInfoList = [],
d = 0; d < r.length; d++) {
var s = r[d].split(";")
, t = {}
, u = 0;
for (u = 0; u < s.length; u++) {
var v = s[u].search("url=");
-1 !== v && (t.URL = s[u].substr(v + 4)),
v = s[u].search("seq="),
-1 !== v && (t.Seq = parseInt(s[u].substr(v + 4)))
b.RTPInfoList.push(t)
} else if (b.ResponseCode === x.UNAUTHORIZED)
"CSeq" === f[0])
else if ("WWW-Authenticate" === f[0]) {
var w = f[1].split(",");
for (d = 0; d < w.length; d++) {
var y = w[d].search("Digest realm=");
if (-1 !== y) {
e = w[d].substr(y + 13);
var z = e.split('"');
b.Realm = z[1]
if (y = w[d].search("nonce="),
-1 !== y) {
e = w[d].substr(y + 6);
var A = e.split('"');
b.Nonce = A[1]
return b
function n(a) {
var b = {}
, c = [];
b.Sessions = c;
var d = null;
var e = a.split("\r\n\r\n");
d = e[1]
} else
d = a;
var f = d.split("\r\n")
, g = 0
, h = !1;
for (g = 0; g < f.length; g++) {
var i = f[g].split("=");
if (i.length > 0)
switch (i[0]) {
case "a":
var j = i[1].split(":");
if (j.length > 1)
if ("control" === j[0]) {
var k = f[g].search("control:");
h === !0 ? -1 !== k && (b.Sessions[b.Sessions.length - 1].ControlURL = f[g].substr(k + 8)) : -1 !== k && (b.BaseURL = f[g].substr(k + 8))
} else if ("rtpmap" === j[0]) {
var l = j[1].split(" ");
b.Sessions[b.Sessions.length - 1].PayloadType = l[0];
var m = l[1].split("/");
b.Sessions[b.Sessions.length - 1].CodecMime = m[0],
m.length > 1 && (b.Sessions[b.Sessions.length - 1].ClockFreq = m[1])
} else if ("framesize" === j[0]) {
var n = j[1].split(" ");
if (n.length > 1) {
var o = n[1].split("-");
b.Sessions[b.Sessions.length - 1].Width = o[0],
b.Sessions[b.Sessions.length - 1].Height = o[1]
} else if ("framerate" === j[0])
b.Sessions[b.Sessions.length - 1].Framerate = j[1];
else if ("fmtp" === j[0]) {
var p = f[g].split(" ");
if (p.length < 2)
continue;
for (var q = 1; q < p.length; q++) {
var r = p[q].split(";")
, s = 0;
for (s = 0; s < r.length; s++) {
var t = r[s].search("mode=");
if (-1 !== t && (b.Sessions[b.Sessions.length - 1].mode = r[s].substr(t + 5)),
t = r[s].search("config="),
-1 !== t && (b.Sessions[b.Sessions.length - 1].config = r[s].substr(t + 7),
L.config = b.Sessions[b.Sessions.length - 1].config,
L.clockFreq = b.Sessions[b.Sessions.length - 1].ClockFreq,
L.bitrate = b.Sessions[b.Sessions.length - 1].Bitrate),
t = r[s].search("sprop-vps="),
-1 !== t && (b.Sessions[b.Sessions.length - 1].VPS = r[s].substr(t + 10)),
t = r[s].search("sprop-sps="),
-1 !== t && (b.Sessions[b.Sessions.length - 1].SPS = r[s].substr(t + 10)),
t = r[s].search("sprop-pps="),
-1 !== t && (b.Sessions[b.Sessions.length - 1].PPS = r[s].substr(t + 10)),
t = r[s].search("sprop-parameter-sets="),
-1 !== t) {
var u = r[s].substr(t + 21)
, v = u.split(",");
v.length > 1 && (b.Sessions[b.Sessions.length - 1].SPS = v[0],
b.Sessions[b.Sessions.length - 1].PPS = v[1])
break;
case "m":
var w = i[1].split(" ")
, x = {};
x.Type = w[0],
x.Port = w[1],
x.Payload = w[3],
b.Sessions.push(x),
h = !0;
break;
case "b":
if (h === !0) {
var y = i[1].split(":");
b.Sessions[b.Sessions.length - 1].Bitrate = y[1]
return b
var a = a
, o = null
, p = 6
, q = null
, r = null
, s = 0
, t = 0
, u = !1
, v = !1
, w = new WorkerManager
, x = {
OK: 200,
UNAUTHORIZED: 401,
NOTFOUND: 404,
INVALID_RANGE: 457,
NOTSERVICE: 503,
DISCONNECT: 999
, y = 4e4
, z = ""
, A = []
, B = 1
, C = null
, D = {}
, E = "Options"
, F = null
, G = null
, H = ""
, I = !1
, J = null
, K = !1
, L = {}
, M = b
, N = null
, O = {}
, P = "";
return c.prototype = {
init: function(a, b) {
w.init(a, b)
connect: function() {
o || (o = new WebSocket(a),
o.binaryType = "arraybuffer",
o.addEventListener("message", j, !1),
o.onopen = function() {
var a = i("OPTIONS " + M + " RTSP/1.0\r\nCSeq: " + B + "\r\n\r\n");
o.send(a)
o.onerror = function() {
w.openWebSocketError()
disconnect: function() {
h(d("TEARDOWN", null, null)),
clearInterval(J),
J = null,
null !== o && o.readyState === WebSocket.OPEN && (o.close(),
o = null,
G = null),
w.terminate()
controlPlayer: function(a) {
var b = "";
switch (P = a.command,
a.command) {
case "PLAY":
if (E = "Play",
null != a.range) {
b = d("PLAY", null, null, a.range);
break
b = d("PLAY", null, null),
P && w.initStartTime();
break;
case "PAUSE":
if ("PAUSE" === E)
break;
E = "PAUSE",
b = d("PAUSE", null, null);
break;
case "SCALE":
b = d("SCALE", null, null, a.data),
w.playbackSpeed(a.data);
break;
case "TEARDOWN":
b = d("TEARDOWN", null, null);
break;
case "audioPlay":
case "volumn":
case "audioSamplingRate":
w.controlAudio(a.command, a.data);
break;
default:
debug.log("未知指令: " + a.command)
"" != b && h(b)
setLiveMode: function(a) {
w.setLiveMode(a)
setRTSPURL: function(a) {
M = a
setCallback: function(a, b) {
"GetFrameRate" === a ? N = b : w.setCallback(a, b),
"Error" == a && (C = b)
setUserInfo: function(a, b) {
O.username = a,
O.passWord = b
capture: function(a) {
w.capture(a)
new c
