RTSP stream for Ezviz LC1C camera does not work
Hi everybody.
Maybe someone can tell why the rtsp stream from one camera does not work. The stream works from all cameras, but does not work from the Ezviz LC1C camera.
And the Ezviz integration doesn’t work either.
I have installed RUS region integration. Authentication went smoothly. But all devices and entities are unavailable. The camera works fine in the Ezviz app.
I also cannot connect to the camera using the rtsp protocol. I use rtsp://admin:[email protected]:554/streaming/Channels/1. No luck.
Other hikvision cameras work without problems using the rtsp protocol.
If i connect from another computer via VLC media player, then the stream works.
Image encryption off.
Has anyone come across this?
Logger: libav.tcp
Source: components/stream/worker.py:367
First occurred: 10:48:19 AM (25 occurrences)
Last logged: 10:57:50 AM
Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:42:51 INFO (MainThread) [homeassistant.setup] Setting up ezviz
2021-10-27 10:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain ezviz took 0.0 seconds
2021-10-27 10:43:17 ERROR (MainThread) [homeassistant.components.ezviz.coordinator] Timeout fetching ezviz data
2021-10-27 10:43:17 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for ezviz integration not ready yet: None; Retrying in background
2021-10-27 10:48:52 ERROR (MainThread) [homeassistant.components.ezviz.coordinator] Timeout fetching ezviz data
2021-10-27 10:49:38 ERROR (MainThread) [homeassistant.components.ezviz.coordinator] Timeout fetching ezviz data
2021-10-27 10:50:42 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:50:42 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554/11
2021-10-27 10:50:43 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:50:43 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554/cam/realmonitor?channel=1&subtype=0&unicast=true
2021-10-27 10:50:43 ERROR (MainThread) [homeassistant.components.ezviz.coordinator] Timeout fetching ezviz data
2021-10-27 10:50:43 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554/Streaming/Channels/101
2021-10-27 10:55:52 ERROR (stream_worker) [homeassistant.components.stream.worker] Error demuxing stream:
2021-10-27 10:55:52 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:55:52 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554/11
2021-10-27 10:55:53 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:55:53 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554/cam/realmonitor?channel=1&subtype=0&unicast=true
2021-10-27 10:55:54 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:55:54 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554/Streaming/Channels/101
2021-10-27 10:55:55 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:55:55 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554
2021-10-27 10:55:58 ERROR (SyncWorker_5) [pyaarlo] authentication failed
2021-10-27 10:55:58 ERROR (SyncWorker_5) [custom_components.aarlo] unable to connect to Arlo: attempt=7,sleep=300,error=authentication failed
2021-10-27 10:55:59 ERROR (MainThread) [homeassistant.components.ezviz.coordinator] Timeout fetching ezviz data
2021-10-27 10:56:04 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:56:04 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67/Streaming/Channels/101
2021-10-27 10:56:05 ERROR (stream_worker) [libav.tcp] Connection to tcp://192.168.0.67:554?timeout=5000000 failed: Operation timed out
2021-10-27 10:56:05 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream rtsp://****:****@192.168.0.67:554/streaming/Channels/1
