I have the webRTC integration and the custom card available. When im pasting the URL for the camera in the custom card, I get the message: mse: sources unavailable: 1.
Further more, I have also installed the RTSPtoWeb - webRTC, and tried to upload a glance card with video stream. This results in a still picture from the camera, before the picture is replaced with the following error message: Failed to start WebRTC stream: RTSPtoWeb server failure: stream channel codec not ready, possible stream offline: Internal Server Error
Is it a workaround for this problem, have I done something wrong in the integrations process, or is it the fact that the stream is RTSPS, not RTSP?
@dictus.jurgen Did you try @faxxyy suggestion?
I tried putting using the url from Unifi with rtsps change to rtspx and remove the parameter ?enableSrtp from the end of the url without sucess.
@dictus.jurgen@SebastianB I got this to work. Try modifying the url by changing the port number to 7747 and removing the s and the parameter at the end. I got this from the Ubiquiti forums.
Did anyone fully solve this? I know you can use the standard RTSP stream from Unifi Protect, using rtsp://ipaddress:7447/cameratoken, but I am finding that the RTSPtoWebRTSP add on is automatically changing the URL back to the unifi default rtsps one.
Anyone been able to work around this issue? The standard RTSP from Protect works fine in my Synology system.
