Hi
I’m trying to setup my Ruckus Unleashed AP as a device tracker, I cannot however seem to find the OID to use for snmp, does anyone know the OID for Ruckus Unleashed? (Not Ruckus ZD) or some other way to use it as a device tracker?
Hi
SNMP enumeration could help, like snmpwalk
Did you manage to solve this? Im interested!
Nope I gave up in the end.
I even tried stuff such as using a logserver, but the logging is inconsistent so that wasn’t reliable either.
Anyone figured this out yet?
I was looking at buying a couple of Ruckus APs does this work alright?
I unfortunately haven’t gotten it to work, it seems like some combination in my configuration makes it lock up, preventing the ssh call from returning.
I did however test it on a new instance where it worked as intended, so depending on what else you are using, it may or may not work.
I have a R310 and I use baseoid: 1.3.6.1.4.1.25053.1.1.6.1.1.2.1.1.1
How do you configure the component?
