Can’t find any breaking changes in 0.85.1 which could affect a rule that was working for 2 years.
85 and not 86 introducing a breaking change with time_pattern
Script checker also keeps silence. but in the logs
[homeassistant.components.automation] Error while executing automation automation.sound_vannaya_gong_at_12_clock. Invalid data for call_service at pos 1: Service does not match format .
- alias: Sound Vannaya Gong at 12 Clock
initial_state: 'on'
platform: time
hours: 12
minutes: 00
seconds: 0
condition:
- condition: state
entity_id: input_boolean.rules_away
state: 'off'
- condition: state
entity_id: input_boolean.rules_sleeping
state: 'off'
- service_template: >
{% if states.media_player.vannaya.state == "paused" or states.media_player.vannaya.state == "idle" %}
{% else %}
media_player.media_pause
{% endif %}
entity_id: media_player.vannaya
- service: media_player.volume_set
volume_level: 1.0
- service: shell_command.sound_12am
is it just the way it’s been pasted into the forum? The indentation looks out for the listed service calls. They should be indented 2 spaces, then the dash relative to action…same for the conditions
but looking at the indentation of everything relative to ‘alias’, it looks like maybe its a forum post thing… indentation is off
### YOU NEED TO PUT A SERVICE HERE ### <-----------------
{% else %}
{% endif %}
@tom_l is right and this has been the bane of my (HA) life.
I wish service_template would just do nothing if none of the if conditions are met.
What is interesting though is that you say it has been working for two years. The only way I can see that that would be true is if your if condition has never been true. And if that is the case it is possible you might be suffering from a problem that I am with media_player states seemingly being inconsistent / wrong / unexpected. See here… Sonos component and unexpected state changes (BUG?)
(I use Sonos but maybe it is a more general issue?)
- alias: 'Sound Vannaya Gong at 12 Clock'
id: 'Sound Vannaya Gong at 12 Clock'
initial_state: 'on'
platform: time
at: '12:00:00'
condition:
- condition: template
value_template: >
{{ is_state('input_boolean.rules_away','off')}}
value_template: >
{{ is_state('input_boolean.rules_sleeping','off')}}
{% if states('media_player.vannaya') in ['paused', 'idle'] %} #add media_player.command
{% else %} media_player.media_pause
{% endif %}
volume_level: 1.0
edited the spacing, use states() format all over, changed to the new time trigger format, changed the condition templates so you can check them in dev-template, compacted the service_template (check too in dev-template) and remember to add a service in the ‘true’ section…
Strangely enough your code worked without errors in the log
Of course i didn’t put anything to the #add media_player.command as this is the only way to tell the template to do nothing. Very strange…
it takes care of situations where entities are not or not yet initialized, and stop a template from throwing an error, see Template - Home Assistant for more explanation.
I also think is much better on the eye, and easier to spot typo’s. But that’s just my preference.
