Hey guys,
im struggling a little bit, or better said i have no idea how i could realize it.
I created a bash script which checks the plex cpu load if it reaches a specified value to spinup my hdd:
#!/bin/bash
# ######### Settings ##################
cpu_threshold=10 # Disks spin up if Plex container's CPU load exceeds this value
# ######### Script ####################
while true; do
plex_cpu_load=$(docker stats --no-stream | grep -i plex | awk '{sub(/%/, "");print $3}')
if awk 'BEGIN {exit !('$plex_cpu_load' > '$cpu_threshold')}'; then
echo "Container's CPU load exceeded threshold"
echo "Spin up disk /dev/sda"
dd if=/dev/sda bs=4096 count=1 of=/dev/null iflag=direct
fi
done
My plan was to execute this via home assistant if [sensor.docker_plex_state] = running
I added my bash script to /config/scripts/ and added it to shellcommand.yaml
plex_spinup_disk: /bin/bash /config/scripts/plex_spinup_hdd.sh
and scripts.yaml
plex_spinup_disk:
alias: plex_spinup_disk
sequence:
- service: shell_command.plex_spinup_disk
and this is my automation:
description: ""
- platform: state
entity_id:
- sensor.docker_plex_state
to: running
condition: []
- service: script.plex_spinup_disk
data: {}
mode: single
I’m aware that home assistant has a repeat until option but it should only run as long and not be repeated until… thatswhy im confused.
Perhaps someone has a idea.
Greetings
Dany
