Hi friends I have this script but condition time is not working, any advice?
alias: turn light on movement
description: turn light on movement
use_blueprint:
path: homeassistant/motion_light.yaml
input:
motion_entity: binary_sensor.lumi_lumi_sensor_motion_aq2_iaszone
light_target:
device_id: 2200d041323efe7700991a82370c1c6e
no_motion_wait: 600
condition: time
before: "20:00:00"
after: "07:00:00"
Is this the default home assistant Blueprint? Also is it a script or an automation blueprint? (you said script)
If you are talking about the default home assistant motion light blueprint, there are no inputs for these:
condition: time
before: "20:00:00"
after: "07:00:00"
If you want to add things, you will need to edit the blueprint not the calling automation.
Otherwise if you look in the blueprint exchange you can probably find a motion light blueprint that does this. There are many motion light Blueprints in there.
