I am fairly new to Home Assistant and my knowledge on YAML is very limited. I do just about everything in the UI. I can however follow simple yaml code fairly easily
Here is my scenario. In South Africa we struggle with load shedding and I have set automations to switch off certain lights and appliances during load shedding. I have installed a Tuya loading sheeding detector which is a modified garage opener. HA then detects that the mains power has been cut. If my battery backup system last the period of load shedding then I have no problem. However if my batteries run out and i lose power completely for a time and then comes back on the my automation just sits and do not trigger.
I run HA on an Intel NUC and its set to power up automatically when power comes back.
How do i get automation to look for return of power and trigger automatically or alternatively to continally check for power availabilty.
Would appreciate some help.
jchh
(my username is my initials (and my first name isn't John))
2
One way is to trigger the automation on restart:
- alias: "Homeassistant restart"
description: "runs only on restart"
initial_state: true # ensure automation is turned on when restarting HA
- platform: homeassistant
event: start
condition: []
