Run automation at beginning of month?
Hi all,
I want to make an automation to reset my energy meters and send me an e-mail report at 00:00:00 on day 0 of a month. I got the notification and service call parts working. I just can’t figure out how to make it go at the beginning (or end) of the month. I can run it daily using the time trigger, but couldn’t get it much farther than that.
Any help appreciated. Thanks.
  platform: time
  at: '00:00:01'
condition:
  condition: template
  value_template: "{{ now().day == 1 }}"
Thanks. Is now() more efficient than adding the time_date sensor and polling that? I saw that with some searching but looks like a lot of templates use now().
I set up a test to run tonight. I’ll let you know how it goes.
I don’t think there is any effect on efficiency. It’s just what works best for the circumstance.
Worked last night. I’ll reconfigure for first of the month and we’ll see then.
Thanks for the help!
hey!
will this work with month as well?
thx
It certainly will.
Thank you
So i will try this:
  condition:
  - condition: template
    value_template: 'value_template: "{{ now().month == 10 }}"'
By the way: how I can make this a trigger? Trigger if month change to „10“
But with the condition should result in same
Thx
You can’t use now() in a trigger as it is only evaluated once. So in a condition it is evaluated once for every time the automation triggers, but in a trigger it would not ever be evaluated again.
the new replacement would probably do:
{{as_local(states.sensor.time.last_updated).month == 10}}
in this case maybe even better
{{as_local(states.sensor.date.last_updated).month == 10}}
since that only triggers once a day
