Hi all.
I’m developing a dashboard for irrigation.
Most of the settings are automatic, I set the days, time and duration and the automations do all the work.
However, I need a button for manual activation of irrigation for a variable duration.
I have created a input_button and input_number
This is the dashboard code:
- type: custom:button-card
entity: input_button.irrigazione_manuale
name: "START Irrigazione Manuale"
tap_action:
action: call_service
service: automation.trigger
service_data:
entity_id: automation.irrigazione_manuale_zona_1
And this is the automation:
alias: Irrigazione Manuale Zona 1
description: ""
trigger: []
condition: []
- type: turn_on
device_id: 59942181bceb160e186d58a5da290189
entity_id: switch.irrigazione_orto
domain: switch
- delay:
hours: 0
minutes: "{{ states('input_number.zone1_manual_duration') | int }}"
seconds: 0
milliseconds: 0
- type: turn_off
domain: switch
mode: single
but it does not work, the automation not start.
Where am i wrong?
Regards,
Marco
Troon
(Troon)
May 5, 2023, 7:28am
2
Your indentation is wrong on the button card, and it’s data
not service_data
. Should be thus:
tap_action:
An automation without a trigger is a script — perhaps write it as a script and call it like that?
koying
(Chris B)
May 5, 2023, 7:33am
3
Besides, if your “automation” does not actually have a trigger, you should make it a script
If it’s just an example, you might want to use an actual button helper:
Thank.
Yes, you have right
I’m trying via script too, but the result is the same. I tried changing indentation and service_data to data but it doesn’t work.
tap_action:
service: script.turn_on
entity_id: script.irrigazione_manuale_zona_1
Troon
(Troon)
May 5, 2023, 7:42am
5
You have to create a script — you can’t just call the automation as a script.
Does your existing automation work if you trigger it manually?
Yes, with “Button” it works fine, but I have created a heavily customized dashboard and would like to continue using the custom button
Yes, I have created the script and worked fine if called from “button”
sequence:
- type: turn_on
domain: switch
- delay:
hours: 0
seconds: 0
milliseconds: 0
- type: turn_off
domain: switch
mode: single
And yes, the automation work if manually run
koying
(Chris B)
May 5, 2023, 7:50am
8
It doesn’t matter how you display it.
You can use its button.press
service.
But yeah, if you actually go to a script, this is irrelevant
I am an idiot!!!
Is not: action: call_service
but: action: call-service
Sorry for wasting your time!
Marco
Troon
(Troon)
May 5, 2023, 8:03am
10
Well spotted. I’m annoyed I didn’t see that. Glad it works now!
kilopter
(Kiloptero)
January 28, 2024, 5:47pm
11
hi! in triying to create and automation coming from an input with luck… any idea?
alias: piscina
description: “”
platform: numeric_state
entity_id:
sensor.living_clima_temperature
above: input_number.termostato_piscina
for:
hours: 0
minutes: 0
seconds: 0
entity_id:
below: input_number.termostato_piscina
for:
hours: 0
minutes: 0
seconds: 0
condition:
choose:
conditions:
condition: trigger
id:
service: input_boolean.turn_off
entity_id: input_boolean.termostato_on_off_piscina
data: {}
conditions:
condition: trigger
id:
prender piscina
sequence:
service: input_boolean.turn_on
data: {}
mode: single
koying
(Chris B)
January 29, 2024, 9:38am
12
@kilopter This is unrelated to this thread, open a new one.
And format your code. At first sight you invented that trigger
has a choose
