Run docker-compose from Home Assistant ssh terminal?
I have the ssh addon (the community one) installed in my Hass.io but of course it’s limited what commands I can use there.
U have a docker compose script that updates non home assistant containers, tears down the containers and then restarts them but even if I copy the script file to the /config folder I cannot execute the script as it says docker-compose is not found.
How can I let the Home Assistant terminal run this script?
I have a couple of containers that just chew memory like there’s no tomorrow and I’d love to make a button to just run the script…
I have the addon configured to use the root user but of course that’s only for that container I think
Why not use ha-dockermon? You don’t have to tear down the entire compose to restart it
I don’t want to touch anything in HA at all - I just use hassio to upddate and manage anything to do with home assistant. I want to do this to containers I manage with compose outside home assistant… it’s entirely possible I’m misunderstanding you though…
Actually I think this will do it as you suggest!
I’m going to have a go at that.
Yep. :wink:
Don’t let the name fool you. I use it for a lot of containers that have nothing to do with home assistant.
Oh my gosh!
Combined with Ludeeus’s custom component this is fantastic!
Thanks for the pointer.
Not I have a history graph of the offenders too!
I might even do an automation to ‘manage’ those rogues when memory use hits x%. Hmm. The possibilities.
