Hi folks,
I published home-assistant on balenaHub. which means you can now run it on Single board computers like Raspberry Pi with 1 click using deploy-with-balena button
or join this open-fleet (doesn’t require you to sign up on balenaCloud).
P.S- since balena runs each service as a container, you can run other services like an adguard VPN, adblockers or even 3d printer server on same device alongside
Let me know if you give this a try, happy to have your feedbacks
