wootje-ha
(First Last)
March 25, 2024, 5:20pm
1
I installed Home Assistant Core according to the manual:
https://www.home-assistant.io/installation/linux#install-home-assistant-core
The firrst time it does start and I can access the web interface. After a reboot I cannot access the web interface. I have tried several init.d script to start Home Assistant Core on boot, but so far no succes.
Is there a way to start Home Assitant Core on boot?
It is installed as user “homeassitant”. So I have to start Home Assistant Core with a command and the user that running the command has to be “homeassistant”.
wootje-ha
(First Last)
March 26, 2024, 5:32pm
2
I fixed the issue.
How I fixed the issue:
Create a file named “homeassistant” in “/etc/init.d”.
Copy the code below to the file you just made (check which version of Python you are using).
Make the exacutable: “chmod 0755 /etc/init.d/homeassistant”.
Add the script to run on boot: “update-rc.d homeassistant defaults”.
Reboot your device.
Open in your web browser: http://[Home Assistant IP address]:8123
If you are using Python3.11:
#!/bin/sh
# For Ubuntu:
# description: Home Assistant
# processname: hass
### BEGIN INIT INFO
# Provides: hass
# Required-Start:
# Required-Stop:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Home Assistant service
# Description: Home Assistant
### END INIT INFO
name="HomeAssistant"
pid_file="/var/run/$name.pid"
case "$1" in
start)
su - homeassistant -c '/srv/homeassistant/bin/python3.11 /srv/homeassistant/bin/hass' &>/dev/null &
echo $(pgrep python3.11) > "$pid_file"
echo "Running with PID: $(pgrep python3.11)"
stop)
echo -n "Stopping $name.."
kill $(pgrep python3.11)
rm "/var/run/$name.pid"
restart)
stop
start
status)
if $(pgrep hass); then
else
echo "$name is not running"
exit 1
fi
echo "Usage: $0 {start|stop|restart|status}"
exit 1
esac
exit 0
If you are using Python3.12:
#!/bin/sh
# For Ubuntu:
# processname: hass
### BEGIN INIT INFO
# Provides: hass
# Required-Start:
# Required-Stop:
### END INIT INFO
case "$1" in
start)
su - homeassistant -c '/usr/local/bin/python3.12 /srv/homeassistant/bin/hass' &>/dev/null &
echo $(pgrep python3.12) > "$pid_file"
stop)
kill $(pgrep python3.12)
restart)
stop
start
status)
echo "Running with PID: $(pgrep python3.12)"
else
exit 1
fi
exit 1
esac
exit 0
