Run notification script for 3 different devices from the same automation
Hello guys!
Im trying to send a notification to 3 diferent android devices with yes / no question to turn on a water heater.
What I was expecting to happen is, when someone answers “yes”, that script finishes, but the other 2 keep waiting for an answer.
However, when I can the 3 scripts from an automation (with script.turn_on) if just 1 person answers yes or no , all 3 scripts finish with the same answer at the same time.
I already tried to use parallel mode on each script but it still does the same.
The 3 actionable notification scripts are created with a blueprint.
Does anyone might know what is happening?
Thank you very much!
Do you mind sending a screenshot of the automation, and script?
Sure,
This is the automation
And this is one of the script (they are exactly the same, but the device used for the notification changes:
Perhaps set a timeout on the notification. ?
