Run out of HA Virtual Box storage
I’m running HA on windows 11 virtual box. I used 900G hdd storage because my frigate videos & photos take space very much and very fast even though I write only 1 day retain in frigate.yml. Right now, I notice frigate cameras don’t show in front-end. I think my HA run out of storage. I check my storage but HA didn’t allow me to show the storage. I think that I need to delete recorded videos. So I go to add ons to start sumba share add on but HA didn’t allow me to go there. When I click add on, I only see below error.
# Troubleshooting
1. If you just started, make sure you have given the Supervisor enough time to start.
2. [Check the Observer](http://homeassistant.local:4357/)
3. Try a reboot of the host
4. [Check System Health](http://192.168.1.xxx:8123/config/info)
5. [Ask for help](https://www.home-assistant.io/help/)
Pls help me how can I start samba share add on and how can I delete frigate media files. ( I always stop and never start samba share add on after HA boot up.)
Now I can’t run virtual box. Below is virtual box log. Pls help.
00:00:03.590472 OS Product: Windows 10
00:00:03.590472 OS Release: 10.0.19045
00:00:03.590473 OS Service Pack:
00:00:03.639943 DMI Product Name: OptiPlex 3070
00:00:03.642291 DMI Product Version:
00:00:03.642298 Firmware type: UEFI
00:00:03.642624 Secure Boot: VERR_PRIVILEGE_NOT_HELD
00:00:03.642634 Host RAM: 8001MB (7.8GB) total, 4525MB (4.4GB) available
00:00:03.642636 Executable: C:\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
00:00:03.642636 Process ID: 9084
00:00:03.642637 Package type: WINDOWS_64BITS_GENERIC
00:00:03.643304 Installed Extension Packs:
00:00:03.643835   Oracle VM VirtualBox Extension Pack (Version: 7.0.10 r158379; VRDE Module: VBoxVRDP; Crypto Module: VBoxPuelCrypto)
00:00:03.644203 Console: Machine state changed to 'Starting'
00:00:03.644305 Qt version: 5.15.2
00:00:03.650850 GUI: UIMediumEnumerator: Medium-enumeration finished!
00:00:03.726047 SUP: seg #0: R   0x00000000 LB 0x00001000
00:00:03.726057 SUP: seg #1: R X 0x00001000 LB 0x00179000
00:00:03.726059 SUP: seg #2: R   0x0017a000 LB 0x00051000
00:00:03.726061 SUP: seg #3: RW  0x001cb000 LB 0x00013000
00:00:03.726064 SUP: seg #4: R   0x001de000 LB 0x00011000
00:00:03.726065 SUP: seg #5: RW  0x001ef000 LB 0x00004000
00:00:03.726067 SUP: seg #6: R   0x001f3000 LB 0x00010000
00:00:03.726069 SUP: seg #7: R X 0x00203000 LB 0x00002000
00:00:03.726071 SUP: seg #8: R   0x00205000 LB 0x00007000
00:00:03.727090 SUP: Loaded VMMR0.r0 (C:\Program Files\Oracle\VirtualBox/VMMR0.r0) at 0xXXXXXXXXXXXXXXXX - ModuleInit at XXXXXXXXXXXXXXXX and ModuleTerm at XXXXXXXXXXXXXXXX using the native ring-0 loader
00:00:03.727100 SUP: VMMR0EntryEx located at XXXXXXXXXXXXXXXX and VMMR0EntryFast at XXXXXXXXXXXXXXXX
00:00:03.727102 SUP: windbg> .reload /f C:\Program Files\Oracle\VirtualBox/VMMR0.r0=0xXXXXXXXXXXXXXXXX
00:00:03.730086 Guest OS type: 'Linux_64'
00:00:03.730367 fHMForced=true - No raw-mode support in this build!
00:00:03.732483 File system of 'E:\haos_ova-10.4.vdi\haos_ova-10.4.vdi' is ntfs
00:00:03.794064 Audio: Detected default audio driver type is 'HostAudioWas'
00:00:03.807304 Shared Clipboard: Service loaded
00:00:03.807314 Shared Clipboard: Mode: Off
00:00:03.807528 Shared Clipboard: Service running in normal mode
00:00:03.819649 Drag and drop service loaded
00:00:03.819655 Drag and drop mode: Off
00:00:03.840417 ************************* CFGM dump *************************
00:00:03.840421 [/] (level 0)
00:00:03.840422   CpuExecutionCap   <integer> = 0x0000000000000064 (100)
00:00:03.840423   EnablePAE         <integer> = 0x0000000000000001 (1)
00:00:03.840424   HMEnabled         <integer> = 0x0000000000000001 (1)
00:00:03.840425   MemBalloonSize    <integer> = 0x0000000000000000 (0, 0 B)
00:00:03.840427   Name              <string>  = "HASS" (cb=5)
00:00:03.840428   NumCPUs           <integer> = 0x0000000000000004 (4)
00:00:03.840429   PageFusionAllowed <integer> = 0x0000000000000000 (0)
00:00:03.840429   RamHoleSize       <integer> = 0x0000000020000000 (536 870 912, 512.0 MiB)
00:00:03.840430   RamSize           <integer> = 0x0000000100000000 (4 294 967 296, 4.0 GiB)
00:00:03.840431   TimerMillies      <integer> = 0x000000000000000a (10)
00:00:03.840432   UUID              <bytes>   = "14 75 70 f2 8f d7 79 47 9c ca e3 9b 60 69 9b 90" (cb=16)
00:00:03.840434
00:00:03.840434 [/CPUM/] (level 1)
00:00:03.840435   Enable64bit        <integer> = 0x0000000000000001 (1)
00:00:03.840436   GuestCpuName       <string>  = "host" (cb=5)
00:00:03.840436   NestedHWVirt       <integer> = 0x0000000000000000 (0)
00:00:03.840437   PortableCpuIdLevel <integer> = 0x0000000000000000 (0)
00:00:03.840437   SpecCtrl           <integer> = 0x0000000000000000 (0)
00:00:03.840437
00:00:03.840438 [/CPUM/IsaExts/] (level 2)
00:00:03.840438
00:00:03.840438 [/DBGC/] (level 1)
00:00:03.840439   GlobalInitScript <string>  = "C:\Users\gthsl\.VirtualBox/dbgc-init" (cb=37)
00:00:03.840439   HistoryFile      <string>  = "C:\Users\gthsl\.VirtualBox/dbgc-history" (cb=40)
00:00:03.840440   LocalInitScript  <string>  = "E:\HASS\HASS/dbgc-init" (cb=23)
00:00:03.840440
00:00:03.840440 [/DBGF/] (level 1)
00:00:03.840441   Path <string>  = "E:\HASS\HASS/debug/;E:\HASS\HASS/;cache*E:\HASS\HASS/dbgcache/;C:\Users\gthsl\" (cb=79)
00:00:03.840441
00:00:03.840442 [/Devices/] (level 1)
00:00:03.840442
00:00:03.840442 [/Devices/3c501/] (level 2)
00:00:03.840443
00:00:03.840443 [/Devices/8237A/] (level 2)
00:00:03.840443
00:00:03.840444 [/Devices/8237A/0/] (level 3)
00:00:03.840444   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840445
00:00:03.840445 [/Devices/GIMDev/] (level 2)
00:00:03.840445
00:00:03.840445 [/Devices/GIMDev/0/] (level 3)
00:00:03.840446   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840446
00:00:03.840447 [/Devices/VMMDev/] (level 2)
00:00:03.840447
00:00:03.840447 [/Devices/VMMDev/0/] (level 3)
00:00:03.840448   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840448   PCIDeviceNo   <integer> = 0x0000000000000004 (4)
00:00:03.840449   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840449   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840450
00:00:03.840450 [/Devices/VMMDev/0/Config/] (level 4)
00:00:03.840450   GuestCoreDumpDir <string>  = "E:\HASS\HASS\Snapshots" (cb=23)
00:00:03.840451
00:00:03.840451 [/Devices/VMMDev/0/LUN#0/] (level 4)
00:00:03.840452   Driver <string>  = "HGCM" (cb=5)
00:00:03.840452
00:00:03.840452 [/Devices/VMMDev/0/LUN#0/Config/] (level 5)
00:00:03.840453
00:00:03.840453 [/Devices/VMMDev/0/LUN#999/] (level 4)
00:00:03.840454   Driver <string>  = "MainStatus" (cb=11)
00:00:03.840454
00:00:03.840454 [/Devices/VMMDev/0/LUN#999/Config/] (level 5)
00:00:03.840455   First                <integer> = 0x0000000000000000 (0)
00:00:03.840456   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:03.840456   Last                 <integer> = 0x0000000000000000 (0)
00:00:03.840456   iLedSet              <integer> = 0x0000000000000006 (6)
00:00:03.840457
00:00:03.840457 [/Devices/acpi/] (level 2)
00:00:03.840458
00:00:03.840458 [/Devices/acpi/0/] (level 3)
00:00:03.840458   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840459   PCIDeviceNo   <integer> = 0x0000000000000007 (7)
00:00:03.840459   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840459   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840460
00:00:03.840460 [/Devices/acpi/0/Config/] (level 4)
00:00:03.840461   CpuHotPlug          <integer> = 0x0000000000000000 (0)
00:00:03.840461   FdcEnabled          <integer> = 0x0000000000000000 (0)
00:00:03.840462   HostBusPciAddress   <integer> = 0x0000000000000000 (0)
00:00:03.840462   HpetEnabled         <integer> = 0x0000000000000000 (0)
00:00:03.840463   IOAPIC              <integer> = 0x0000000000000001 (1)
00:00:03.840463   IocPciAddress       <integer> = 0x0000000000010000 (65 536)
00:00:03.840464   NumCPUs             <integer> = 0x0000000000000004 (4)
00:00:03.840464   Parallel0IoPortBase <integer> = 0x0000000000000000 (0)
00:00:03.840465   Parallel0Irq        <integer> = 0x0000000000000000 (0)
00:00:03.840465   Parallel1IoPortBase <integer> = 0x0000000000000000 (0)
00:00:03.840465   Parallel1Irq        <integer> = 0x0000000000000000 (0)
00:00:03.840466   Serial0IoPortBase   <integer> = 0x0000000000000000 (0)
00:00:03.840466   Serial0Irq          <integer> = 0x0000000000000000 (0)
00:00:03.840467   Serial1IoPortBase   <integer> = 0x0000000000000000 (0)
00:00:03.840467   Serial1Irq          <integer> = 0x0000000000000000 (0)
00:00:03.840467   ShowCpu             <integer> = 0x0000000000000001 (1)
00:00:03.840468   ShowRtc             <integer> = 0x0000000000000000 (0)
00:00:03.840468   SmcEnabled          <integer> = 0x0000000000000000 (0)
00:00:03.840469
00:00:03.840469 [/Devices/acpi/0/LUN#0/] (level 4)
00:00:03.840470   Driver <string>  = "ACPIHost" (cb=9)
00:00:03.840470
00:00:03.840470 [/Devices/acpi/0/LUN#0/Config/] (level 5)
00:00:03.840471
00:00:03.840471 [/Devices/acpi/0/LUN#1/] (level 4)
00:00:03.840471   Driver <string>  = "ACPICpu" (cb=8)
00:00:03.840472
00:00:03.840472 [/Devices/acpi/0/LUN#1/Config/] (level 5)
00:00:03.840473
00:00:03.840473 [/Devices/acpi/0/LUN#2/] (level 4)
00:00:03.840473   Driver <string>  = "ACPICpu" (cb=8)
00:00:03.840474
00:00:03.840474 [/Devices/acpi/0/LUN#2/Config/] (level 5)
00:00:03.840474
00:00:03.840475 [/Devices/acpi/0/LUN#3/] (level 4)
00:00:03.840475   Driver <string>  = "ACPICpu" (cb=8)
00:00:03.840475
00:00:03.840476 [/Devices/acpi/0/LUN#3/Config/] (level 5)
00:00:03.840476
00:00:03.840476 [/Devices/ahci/] (level 2)
00:00:03.840477
00:00:03.840477 [/Devices/ahci/0/] (level 3)
00:00:03.840478   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840478   PCIDeviceNo   <integer> = 0x000000000000000d (13)
00:00:03.840479   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840479   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840479
00:00:03.840479 [/Devices/ahci/0/Config/] (level 4)
00:00:03.840480   Bootable  <integer> = 0x0000000000000001 (1)
00:00:03.840481   PortCount <integer> = 0x0000000000000001 (1)
00:00:03.840481
00:00:03.840481 [/Devices/ahci/0/Config/Port0/] (level 5)
00:00:03.840482   Hotpluggable <integer> = 0x0000000000000000 (0)
00:00:03.840482
00:00:03.840482 [/Devices/ahci/0/LUN#0/] (level 4)
00:00:03.840483   Driver <string>  = "VD" (cb=3)
00:00:03.840483
00:00:03.840483 [/Devices/ahci/0/LUN#0/Config/] (level 5)
00:00:03.840484   BlockCache <integer> = 0x0000000000000001 (1)
00:00:03.840485   Format     <string>  = "VDI" (cb=4)
00:00:03.840485   Mountable  <integer> = 0x0000000000000000 (0)
00:00:03.840486   Path       <string>  = "E:\haos_ova-10.4.vdi\haos_ova-10.4.vdi" (cb=39)
00:00:03.840486   Type       <string>  = "HardDisk" (cb=9)
00:00:03.840486   UseNewIo   <integer> = 0x0000000000000001 (1)
00:00:03.840487
00:00:03.840487 [/Devices/ahci/0/LUN#0/Config/Plugins/] (level 6)
00:00:03.840488
00:00:03.840488 [/Devices/ahci/0/LUN#0/Config/Plugins/VDPluginCrypt/] (level 7)
00:00:03.840489   Path <string>  = "C:\Program Files\Oracle\VirtualBox\ExtensionPacks\Oracle_VM_VirtualBox_Extension_Pack\win.amd64\VDPluginCrypt.DLL" (cb=114)
00:00:03.840490
00:00:03.840490 [/Devices/ahci/0/LUN#0/Config/VDConfig/] (level 6)
00:00:03.840491   AllocationBlockSize <string>  = "1048576" (cb=8)
00:00:03.840491
00:00:03.840491 [/Devices/ahci/0/LUN#999/] (level 4)
00:00:03.840492   Driver <string>  = "MainStatus" (cb=11)
00:00:03.840492
00:00:03.840492 [/Devices/ahci/0/LUN#999/Config/] (level 5)
00:00:03.840493   DeviceInstance       <string>  = "ahci/0" (cb=7)
00:00:03.840493   First                <integer> = 0x0000000000000000 (0)
00:00:03.840494   HasMediumAttachments <integer> = 0x0000000000000001 (1)
00:00:03.840494   Last                 <integer> = 0x0000000000000000 (0)
00:00:03.840495   iLedSet              <integer> = 0x0000000000000004 (4)
00:00:03.840495
00:00:03.840495 [/Devices/apic/] (level 2)
00:00:03.840496
00:00:03.840496 [/Devices/apic/0/] (level 3)
00:00:03.840497   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840497
00:00:03.840497 [/Devices/apic/0/Config/] (level 4)
00:00:03.840498   IOAPIC  <integer> = 0x0000000000000001 (1)
00:00:03.840498   Mode    <integer> = 0x0000000000000003 (3)
00:00:03.840499   NumCPUs <integer> = 0x0000000000000004 (4)
00:00:03.840499
00:00:03.840499 [/Devices/dp8390/] (level 2)
00:00:03.840500
00:00:03.840500 [/Devices/e1000/] (level 2)
00:00:03.840500
00:00:03.840500 [/Devices/e1000/0/] (level 3)
00:00:03.840501   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840502   PCIDeviceNo   <integer> = 0x0000000000000003 (3)
00:00:03.840502   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840502   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840503
00:00:03.840503 [/Devices/e1000/0/Config/] (level 4)
00:00:03.840504   AdapterType    <integer> = 0x0000000000000000 (0)
00:00:03.840504   CableConnected <integer> = 0x0000000000000001 (1)
00:00:03.840504   LineSpeed      <integer> = 0x0000000000000000 (0)
00:00:03.840505   MAC            <bytes>   = "08 00 27 59 06 b4" (cb=6)
00:00:03.840506
00:00:03.840506 [/Devices/e1000/0/LUN#0/] (level 4)
00:00:03.840506   Driver <string>  = "IntNet" (cb=7)
00:00:03.840507
00:00:03.840507 [/Devices/e1000/0/LUN#0/Config/] (level 5)
00:00:03.840508   IfPolicyPromisc      <string>  = "allow-all" (cb=10)
00:00:03.840508   IgnoreConnectFailure <integer> = 0x0000000000000000 (0)
00:00:03.840508   Network              <string>  = "HostInterfaceNetworking-Realtek PCIe GbE Family Controller" (cb=59)
00:00:03.840509   Trunk                <string>  = "\DEVICE\{4089AC93-1ED2-4D63-8D90-232EF8428856}" (cb=47)
00:00:03.840510   TrunkType            <integer> = 0x0000000000000003 (3)
00:00:03.840510
00:00:03.840510 [/Devices/e1000/0/LUN#999/] (level 4)
00:00:03.840511   Driver <string>  = "MainStatus" (cb=11)
00:00:03.840511
00:00:03.840511 [/Devices/e1000/0/LUN#999/Config/] (level 5)
00:00:03.840512   First                <integer> = 0x0000000000000000 (0)
00:00:03.840513   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:03.840513   Last                 <integer> = 0x0000000000000000 (0)
00:00:03.840514   iLedSet              <integer> = 0x0000000000000005 (5)
00:00:03.840514
00:00:03.840514 [/Devices/efi/] (level 2)
00:00:03.840515
00:00:03.840515 [/Devices/efi/0/] (level 3)
00:00:03.840516   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840516
00:00:03.840516 [/Devices/efi/0/Config/] (level 4)
00:00:03.840517   64BitEntry  <integer> = 0x0000000000000001 (1)
00:00:03.840518   APIC        <integer> = 0x0000000000000001 (1)
00:00:03.840518   BootArgs    <string>  = "" (cb=1)
00:00:03.840518   DeviceProps <string>  = "" (cb=1)
00:00:03.840519   EfiRom      <string>  = "VBoxEFI64.fd" (cb=13)
00:00:03.840519   IOAPIC      <integer> = 0x0000000000000001 (1)
00:00:03.840520   McfgBase    <integer> = 0x0000000000000000 (0)
00:00:03.840520   McfgLength  <integer> = 0x0000000000000000 (0)
00:00:03.840520   NumCPUs     <integer> = 0x0000000000000004 (4)
00:00:03.840521   NvramFile   <string>  = "E:\HASS\HASS\HASS.nvram" (cb=24)
00:00:03.840521   UUID        <bytes>   = "14 75 70 f2 8f d7 79 47 9c ca e3 9b 60 69 9b 90" (cb=16)
00:00:03.840522   UuidLe      <integer> = 0x0000000000000001 (1)
00:00:03.840523
00:00:03.840523 [/Devices/efi/0/LUN#0/] (level 4)
00:00:03.840523   Driver <string>  = "NvramStore" (cb=11)
00:00:03.840524
00:00:03.840524 [/Devices/hda/] (level 2)
00:00:03.840525
00:00:03.840525 [/Devices/hda/0/] (level 3)
00:00:03.840525   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840526   PCIDeviceNo   <integer> = 0x0000000000000005 (5)
00:00:03.840526   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840526   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840527
00:00:03.840527 [/Devices/hda/0/AudioConfig/] (level 4)
00:00:03.840528
00:00:03.840528 [/Devices/hda/0/Config/] (level 4)
00:00:03.840528   DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:03.840529
00:00:03.840529 [/Devices/hda/0/LUN#0/] (level 4)
00:00:03.840529   Driver <string>  = "AUDIO" (cb=6)
00:00:03.840530
00:00:03.840530 [/Devices/hda/0/LUN#0/AttachedDriver/] (level 5)
00:00:03.840531   Driver <string>  = "HostAudioWas" (cb=13)
00:00:03.840531
00:00:03.840531 [/Devices/hda/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:03.840532   VmName <string>  = "HASS" (cb=5)
00:00:03.840532   VmUuid <string>  = "f2707514-d78f-4779-9cca-e39b60699b90" (cb=37)
00:00:03.840533
00:00:03.840533 [/Devices/hda/0/LUN#0/Config/] (level 5)
00:00:03.840534   DriverName    <string>  = "HostAudioWas" (cb=13)
00:00:03.840534   InputEnabled  <integer> = 0x0000000000000000 (0)
00:00:03.840534   OutputEnabled <integer> = 0x0000000000000001 (1)
00:00:03.840535
00:00:03.840535 [/Devices/hda/0/LUN#1/] (level 4)
00:00:03.840535   Driver <string>  = "AUDIO" (cb=6)
00:00:03.840536
00:00:03.840536 [/Devices/hda/0/LUN#2/] (level 4)
00:00:03.840536   Driver <string>  = "AUDIO" (cb=6)
00:00:03.840537
00:00:03.840537 [/Devices/i8254/] (level 2)
00:00:03.840537
00:00:03.840538 [/Devices/i8254/0/] (level 3)
00:00:03.840538
00:00:03.840538 [/Devices/i8254/0/Config/] (level 4)
00:00:03.840539
00:00:03.840539 [/Devices/i8259/] (level 2)
00:00:03.840540
00:00:03.840540 [/Devices/i8259/0/] (level 3)
00:00:03.840540   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840541
00:00:03.840541 [/Devices/i8259/0/Config/] (level 4)
00:00:03.840541
00:00:03.840542 [/Devices/ioapic/] (level 2)
00:00:03.840542
00:00:03.840542 [/Devices/ioapic/0/] (level 3)
00:00:03.840543   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840543
00:00:03.840543 [/Devices/ioapic/0/Config/] (level 4)
00:00:03.840544   NumCPUs <integer> = 0x0000000000000004 (4)
00:00:03.840544
00:00:03.840544 [/Devices/mc146818/] (level 2)
00:00:03.840545
00:00:03.840545 [/Devices/mc146818/0/] (level 3)
00:00:03.840546
00:00:03.840546 [/Devices/mc146818/0/Config/] (level 4)
00:00:03.840546   UseUTC <integer> = 0x0000000000000001 (1)
00:00:03.840547
00:00:03.840547 [/Devices/parallel/] (level 2)
00:00:03.840547
00:00:03.840548 [/Devices/pcarch/] (level 2)
00:00:03.840548
00:00:03.840548 [/Devices/pcarch/0/] (level 3)
00:00:03.840549   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840549
00:00:03.840549 [/Devices/pcarch/0/Config/] (level 4)
00:00:03.840550
00:00:03.840550 [/Devices/pci/] (level 2)
00:00:03.840550
00:00:03.840551 [/Devices/pci/0/] (level 3)
00:00:03.840551   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840551
00:00:03.840552 [/Devices/pci/0/Config/] (level 4)
00:00:03.840554   IOAPIC <integer> = 0x0000000000000001 (1)
00:00:03.840555
00:00:03.840555 [/Devices/pcibridge/] (level 2)
00:00:03.840555
00:00:03.840555 [/Devices/pckbd/] (level 2)
00:00:03.840556
00:00:03.840556 [/Devices/pckbd/0/] (level 3)
00:00:03.840557   Trusted <integer> = 0x0000000000000001 (1)
00:00:03.840557
00:00:03.840557 [/Devices/pckbd/0/Config/] (level 4)
00:00:03.840558
00:00:03.840558 [/Devices/pckbd/0/LUN#0/] (level 4)
00:00:03.840558   Driver <string>  = "KeyboardQueue" (cb=14)
00:00:03.840559
00:00:03.840559 [/Devices/pckbd/0/LUN#0/AttachedDriver/] (level 5)
00:00:03.840560   Driver <string>  = "MainKeyboard" (cb=13)
00:00:03.840560
00:00:03.840560 [/Devices/pckbd/0/LUN#0/Config/] (level 5)
00:00:03.840561   QueueSize <integer> = 0x0000000000000040 (64, 64 B)
00:00:03.840562
00:00:03.840562 [/Devices/pckbd/0/LUN#1/] (level 4)
00:00:03.840562   Driver <string>  = "MouseQueue" (cb=11)
00:00:03.840563
00:00:03.840563 [/Devices/pckbd/0/LUN#1/AttachedDriver/] (level 5)
00:00:03.840563   Driver <string>  = "MainMouse" (cb=10)
00:00:03.840564
00:00:03.840564 [/Devices/pckbd/0/LUN#1/Config/] (level 5)
00:00:03.840565   QueueSize <integer> = 0x0000000000000080 (128, 128 B)
00:00:03.840565
00:00:03.840565 [/Devices/pcnet/] (level 2)
00:00:03.840566
00:00:03.840566 [/Devices/piix3ide/] (level 2)
00:00:03.840566
00:00:03.840567 [/Devices/piix3ide/0/] (level 3)
00:00:03.840567   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840568   PCIDeviceNo   <integer> = 0x0000000000000001 (1)
00:00:03.840568   PCIFunctionNo <integer> = 0x0000000000000001 (1)
00:00:03.840568   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840569
00:00:03.840569 [/Devices/piix3ide/0/Config/] (level 4)
00:00:03.840570   Type <string>  = "PIIX4" (cb=6)
00:00:03.840570
00:00:03.840570 [/Devices/piix3ide/0/LUN#2/] (level 4)
00:00:03.840571   Driver <string>  = "VD" (cb=3)
00:00:03.840571
00:00:03.840571 [/Devices/piix3ide/0/LUN#2/Config/] (level 5)
00:00:03.840572   EmptyDrive <integer> = 0x0000000000000001 (1)
00:00:03.840572   Mountable  <integer> = 0x0000000000000001 (1)
00:00:03.840573   Type       <string>  = "DVD" (cb=4)
00:00:03.840573
00:00:03.840573 [/Devices/piix3ide/0/LUN#999/] (level 4)
00:00:03.840574   Driver <string>  = "MainStatus" (cb=11)
00:00:03.840574
00:00:03.840574 [/Devices/piix3ide/0/LUN#999/Config/] (level 5)
00:00:03.840575   DeviceInstance       <string>  = "piix3ide/0" (cb=11)
00:00:03.840576   First                <integer> = 0x0000000000000000 (0)
00:00:03.840576   HasMediumAttachments <integer> = 0x0000000000000001 (1)
00:00:03.840577   Last                 <integer> = 0x0000000000000003 (3)
00:00:03.840577   iLedSet              <integer> = 0x0000000000000003 (3)
00:00:03.840578
00:00:03.840578 [/Devices/serial/] (level 2)
00:00:03.840578
00:00:03.840578 [/Devices/usb-ehci/] (level 2)
00:00:03.840579
00:00:03.840579 [/Devices/usb-ehci/0/] (level 3)
00:00:03.840580   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840580   PCIDeviceNo   <integer> = 0x000000000000000b (11)
00:00:03.840580   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840581   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840581
00:00:03.840581 [/Devices/usb-ehci/0/Config/] (level 4)
00:00:03.840582
00:00:03.840582 [/Devices/usb-ehci/0/LUN#0/] (level 4)
00:00:03.840583   Driver <string>  = "VUSBRootHub" (cb=12)
00:00:03.840583
00:00:03.840583 [/Devices/usb-ehci/0/LUN#0/Config/] (level 5)
00:00:03.840584
00:00:03.840584 [/Devices/usb-ehci/0/LUN#999/] (level 4)
00:00:03.840585   Driver <string>  = "MainStatus" (cb=11)
00:00:03.840585
00:00:03.840585 [/Devices/usb-ehci/0/LUN#999/Config/] (level 5)
00:00:03.840586   First                <integer> = 0x0000000000000000 (0)
00:00:03.840586   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:03.840587   Last                 <integer> = 0x0000000000000000 (0)
00:00:03.840587   iLedSet              <integer> = 0x0000000000000002 (2)
00:00:03.840588
00:00:03.840588 [/Devices/usb-ohci/] (level 2)
00:00:03.840588
00:00:03.840589 [/Devices/usb-ohci/0/] (level 3)
00:00:03.840589   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840590   PCIDeviceNo   <integer> = 0x0000000000000006 (6)
00:00:03.840590   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840590   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840591
00:00:03.840591 [/Devices/usb-ohci/0/Config/] (level 4)
00:00:03.840591
00:00:03.840592 [/Devices/usb-ohci/0/LUN#0/] (level 4)
00:00:03.840592   Driver <string>  = "VUSBRootHub" (cb=12)
00:00:03.840592
00:00:03.840593 [/Devices/usb-ohci/0/LUN#0/Config/] (level 5)
00:00:03.840593
00:00:03.840593 [/Devices/usb-ohci/0/LUN#999/] (level 4)
00:00:03.840594   Driver <string>  = "MainStatus" (cb=11)
00:00:03.840594
00:00:03.840595 [/Devices/usb-ohci/0/LUN#999/Config/] (level 5)
00:00:03.840595   First                <integer> = 0x0000000000000000 (0)
00:00:03.840596   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:03.840596   Last                 <integer> = 0x0000000000000000 (0)
00:00:03.840596   iLedSet              <integer> = 0x0000000000000001 (1)
00:00:03.840597
00:00:03.840597 [/Devices/vga/] (level 2)
00:00:03.840598
00:00:03.840598 [/Devices/vga/0/] (level 3)
00:00:03.840598   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:03.840599   PCIDeviceNo   <integer> = 0x0000000000000002 (2)
00:00:03.840599   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:03.840599   Trusted       <integer> = 0x0000000000000001 (1)
00:00:03.840600
00:00:03.840600 [/Devices/vga/0/Config/] (level 4)
00:00:03.840601   3DEnabled          <integer> = 0x0000000000000000 (0)
00:00:03.840601   CustomVideoModes   <integer> = 0x0000000000000000 (0)
00:00:03.840601   FadeIn             <integer> = 0x0000000000000001 (1)
00:00:03.840602   FadeOut            <integer> = 0x0000000000000001 (1)
00:00:03.840602   HeightReduction    <integer> = 0x0000000000000000 (0)
00:00:03.840603   LogoFile           <string>  = "" (cb=1)
00:00:03.840603   LogoTime           <integer> = 0x0000000000000000 (0)
00:00:03.840604   MonitorCount       <integer> = 0x0000000000000001 (1)
00:00:03.840604   ShowBootMenu       <integer> = 0x0000000000000002 (2)
00:00:03.840604   VMSVGA3dEnabled    <integer> = 0x0000000000000000 (0)
00:00:03.840605   VMSVGAEnabled      <integer> = 0x0000000000000001 (1)
00:00:03.840605   VMSVGAPciBarLayout <integer> = 0x0000000000000001 (1)
00:00:03.840606   VMSVGAPciId        <integer> = 0x0000000000000001 (1)
00:00:03.840606   VRamSize           <integer> = 0x0000000001000000 (16 777 216, 16.0 MiB)
00:00:03.840607
00:00:03.840607 [/Devices/vga/0/LUN#0/] (level 4)
00:00:03.840608   Driver <string>  = "MainDisplay" (cb=12)
00:00:03.840608
00:00:03.840608 [/Devices/vga/0/LUN#0/Config/] (level 5)
00:00:03.840609
00:00:03.840609 [/Devices/vga/0/LUN#999/] (level 4)
00:00:03.840610   Driver <string>  = "MainStatus" (cb=11)
00:00:03.840610
00:00:03.840610 [/Devices/vga/0/LUN#999/Config/] (level 5)
00:00:03.840611   First                <integer> = 0x0000000000000000 (0)
00:00:03.840611   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:03.840612   Last                 <integer> = 0x0000000000000000 (0)
00:00:03.840612   iLedSet              <integer> = 0x0000000000000000 (0)
00:00:03.840613
00:00:03.840613 [/Devices/virtio-net/] (level 2)
00:00:03.840613
00:00:03.840613 [/EM/] (level 1)
00:00:03.840614   TripleFaultReset <integer> = 0x0000000000000000 (0)
00:00:03.840614
00:00:03.840614 [/GCM/] (level 1)
00:00:03.840615   FixerSet <integer> = 0x0000000000000000 (0)
00:00:03.840615
00:00:03.840615 [/GIM/] (level 1)
00:00:03.840616   Provider <string>  = "KVM" (cb=4)
00:00:03.840616
00:00:03.840616 [/HM/] (level 1)
00:00:03.840617   64bitEnabled            <integer> = 0x0000000000000001 (1)
00:00:03.840617   EnableLargePages        <integer> = 0x0000000000000001 (1)
00:00:03.840618   EnableNestedPaging      <integer> = 0x0000000000000001 (1)
00:00:03.840618   EnableUX                <integer> = 0x0000000000000001 (1)
00:00:03.840619   EnableVPID              <integer> = 0x0000000000000001 (1)
00:00:03.840619   Exclusive               <integer> = 0x0000000000000000 (0)
00:00:03.840620   HMForced                <integer> = 0x0000000000000001 (1)
00:00:03.840620   IBPBOnVMEntry           <integer> = 0x0000000000000000 (0)
00:00:03.840621   IBPBOnVMExit            <integer> = 0x0000000000000000 (0)
00:00:03.840621   L1DFlushOnSched         <integer> = 0x0000000000000001 (1)
00:00:03.840621   L1DFlushOnVMEntry       <integer> = 0x0000000000000000 (0)
00:00:03.840622   LovelyMesaDrvWorkaround <integer> = 0x0000000000000001 (1)
00:00:03.840622   MDSClearOnSched         <integer> = 0x0000000000000001 (1)
00:00:03.840623   MDSClearOnVMEntry       <integer> = 0x0000000000000000 (0)
00:00:03.840623   SpecCtrlByHost          <integer> = 0x0000000000000000 (0)
00:00:03.840624   SvmVirtVmsaveVmload     <integer> = 0x0000000000000000 (0)
00:00:03.840624   UseNEMInstead           <integer> = 0x0000000000000000 (0)
00:00:03.840624
00:00:03.840625 [/MM/] (level 1)
00:00:03.840625   CanUseLargerHeap <integer> = 0x0000000000000000 (0)
00:00:03.840625
00:00:03.840625 [/NEM/] (level 1)
00:00:03.840626   Allow64BitGuests        <integer> = 0x0000000000000001 (1)
00:00:03.840626   LovelyMesaDrvWorkaround <integer> = 0x0000000000000001 (1)
00:00:03.840627
00:00:03.840627 [/PDM/] (level 1)
00:00:03.840627
00:00:03.840627 [/PDM/AsyncCompletion/] (level 2)
00:00:03.840628
00:00:03.840628 [/PDM/AsyncCompletion/File/] (level 3)
00:00:03.840629
00:00:03.840629 [/PDM/AsyncCompletion/File/BwGroups/] (level 4)
00:00:03.840630
00:00:03.840630 [/PDM/BlkCache/] (level 2)
00:00:03.840630   CacheSize <integer> = 0x0000000000500000 (5 242 880, 5.0 MiB)
00:00:03.840631
00:00:03.840631 [/PDM/Devices/] (level 2)
00:00:03.840632
00:00:03.840632 [/PDM/Devices/VBoxNvme/] (level 3)
00:00:03.840633   Path         <string>  = "C:\Program Files\Oracle\VirtualBox\ExtensionPacks\Oracle_VM_VirtualBox_Extension_Pack\win.amd64\VBoxNvmeR3.DLL" (cb=111)
00:00:03.840633   R0SearchPath <string>  = "C:\Program Files\Oracle\VirtualBox\ExtensionPacks\Oracle_VM_VirtualBox_Extension_Pack\win.amd64" (cb=96)
00:00:03.840634
00:00:03.840634 [/PDM/Drivers/] (level 2)
00:00:03.840634
00:00:03.840635 [/PDM/Drivers/DrvHostWebcam/] (level 3)
00:00:03.840635   Path <string>  = "C:\Program Files\Oracle\VirtualBox\ExtensionPacks\Oracle_VM_VirtualBox_Extension_Pack\win.amd64\VBoxHostWebcam.DLL" (cb=115)
00:00:03.840636
00:00:03.840636 [/PDM/Drivers/VBoxC/] (level 3)
00:00:03.840636   Path <string>  = "VBoxC" (cb=6)
00:00:03.840637
00:00:03.840637 [/PDM/NetworkShaper/] (level 2)
00:00:03.840637
00:00:03.840637 [/PDM/NetworkShaper/BwGroups/] (level 3)
00:00:03.840638
00:00:03.840638 [/PDM/USB/] (level 2)
00:00:03.840638
00:00:03.840639 [/PDM/USB/VBoxUsbCardReader/] (level 3)
00:00:03.840639   Path <string>  = "C:\Program Files\Oracle\VirtualBox\ExtensionPacks\Oracle_VM_VirtualBox_Extension_Pack\win.amd64\VBoxUsbCardReaderR3.DLL" (cb=120)
00:00:03.840640
00:00:03.840640 [/PDM/USB/VBoxUsbWebcam/] (level 3)
00:00:03.840640   Path <string>  = "C:\Program Files\Oracle\VirtualBox\ExtensionPacks\Oracle_VM_VirtualBox_Extension_Pack\win.amd64\VBoxUsbWebcamR3.DLL" (cb=116)
00:00:03.840641
00:00:03.840641 [/TM/] (level 1)
00:00:03.840641   UTCOffset <integer> = 0x0000000000000000 (0)
00:00:03.840642
00:00:03.840642 [/USB/] (level 1)
00:00:03.840642
00:00:03.840642 [/USB/USBProxy/] (level 2)
00:00:03.840643
00:00:03.840643 [/USB/USBProxy/GlobalConfig/] (level 3)
00:00:03.840644
00:00:03.840644 ********************* End of CFGM dump **********************
00:00:03.840909 HM: HMR3Init: VT-x w/ nested paging and unrestricted guest execution hw support
00:00:03.840960 CPUM: fXStateHostMask=0x7; initial: 0x7; host XCR0=0x1f
00:00:03.842050 CPUM: Matched host CPU INTEL 0x6/0x9e/0xd Intel_Core7_WhiskeyLake with CPU DB entry 'Intel Core i7-6700K' (INTEL 0x6/0x5e/0x3 Intel_Core7_Skylake)
00:00:03.842094 CPUM: MXCSR_MASK=0xffff (host: 0xffff)
00:00:03.842104 CPUM: Microcode revision 0x000000CA
00:00:03.842111 CPUM: Changing leaf 13[0]: EBX=0x440 -> 0x340, ECX=0x440 -> 0x340
00:00:03.842118 CPUM: MSR/CPUID reconciliation insert: 0x0000010b IA32_FLUSH_CMD
00:00:03.842121 CPUM: MSR/CPUID reconciliation insert: 0x0000010a IA32_ARCH_CAPABILITIES
00:00:03.842125 CPUM: MSR fudge: 0x00000001 IA32_P5_MC_TYPE
00:00:03.842127 CPUM: MSR fudge: 0x00000017 IA32_PLATFORM_ID
00:00:03.842129 CPUM: MSR fudge: 0x0000001b IA32_APIC_BASE
00:00:03.842131 CPUM: MSR fudge: 0x0000008b BIOS_SIGN
00:00:03.842133 CPUM: MSR fudge: 0x000000fe IA32_MTRRCAP
00:00:03.842134 CPUM: MSR fudge: 0x00000179 IA32_MCG_CAP
00:00:03.842136 CPUM: MSR fudge: 0x0000017a IA32_MCG_STATUS
00:00:03.842138 CPUM: MSR fudge: 0x000001a0 IA32_MISC_ENABLE
00:00:03.842140 CPUM: MSR fudge: 0x000001d9 IA32_DEBUGCTL
00:00:03.842142 CPUM: MSR fudge: 0x000001db P6_LAST_BRANCH_FROM_IP
00:00:03.842144 CPUM: MSR fudge: 0x000001dc P6_LAST_BRANCH_TO_IP
00:00:03.842146 CPUM: MSR fudge: 0x000001dd P6_LAST_INT_FROM_IP
00:00:03.842148 CPUM: MSR fudge: 0x000001de P6_LAST_INT_TO_IP
00:00:03.842149 CPUM: MSR fudge: 0x00000277 IA32_PAT
00:00:03.842151 CPUM: MSR fudge: 0x000002ff IA32_MTRR_DEF_TYPE
00:00:03.842153 CPUM: MSR fudge: 0x00000400 IA32_MCi_CTL_STATUS_ADDR_MISC
00:00:03.842156 CPUM: MSR fudge: 0xc0000103 AMD64_TSC_AUX
00:00:03.842158 CPUM: MSR fudge: 0x00000122 IA32_TSX_CTRL
00:00:03.842167 CPUM: SetGuestCpuIdFeature: Enabled SYSENTER/EXIT
00:00:03.842169 CPUM: SetGuestCpuIdFeature: Enabled SYSCALL/RET
00:00:03.842171 CPUM: SetGuestCpuIdFeature: Enabled PAE
00:00:03.842173 CPUM: SetGuestCpuIdFeature: Enabled LAHF/SAHF
00:00:03.842175 CPUM: SetGuestCpuIdFeature: Enabled NX
00:00:03.842177 CPUM: SetGuestCpuIdFeature: Enabled LONG MODE
00:00:03.842270 PGM: Host paging mode: AMD64+PGE+NX
00:00:03.842276 PGM: PGMPool: cMaxPages=2304 (u64MaxPages=2084)
00:00:03.842278 PGM: pgmR3PoolInit: cMaxPages=0x900 cMaxUsers=0x1200 cMaxPhysExts=0x1200 fCacheEnable=true
00:00:03.864815 TM: GIP - u32Mode=3 (Invariant) u32UpdateHz=93 u32UpdateIntervalNS=10734900 enmUseTscDelta=2 (Practically Zero) fGetGipCpu=0x1b cCpus=8
00:00:03.864828 TM: GIP - u64CpuHz=3 000 003 765 (0xb2d06cb5)  SUPGetCpuHzFromGip => 3 000 003 765
00:00:03.864871 TM: GIP - CPU: iCpuSet=0x0 idCpu=0x0 idApic=0x0 iGipCpu=0x3 i64TSCDelta=0 enmState=3 u64CpuHz=3000003424(*) cErrors=0
00:00:03.864877 TM: GIP - CPU: iCpuSet=0x1 idCpu=0x1 idApic=0x2 iGipCpu=0x5 i64TSCDelta=0 enmState=3 u64CpuHz=3000003581(*) cErrors=0
00:00:03.864879 TM: GIP - CPU: iCpuSet=0x2 idCpu=0x2 idApic=0x4 iGipCpu=0x4 i64TSCDelta=0 enmState=3 u64CpuHz=3000002428(*) cErrors=0
00:00:03.864882 TM: GIP - CPU: iCpuSet=0x3 idCpu=0x3 idApic=0x6 iGipCpu=0x0 i64TSCDelta=0 enmState=3 u64CpuHz=3000003765(*) cErrors=0
00:00:03.864884 TM: GIP - CPU: iCpuSet=0x4 idCpu=0x4 idApic=0x8 iGipCpu=0x2 i64TSCDelta=0 enmState=3 u64CpuHz=2999996308(*) cErrors=0
00:00:03.864886 TM: GIP - CPU: iCpuSet=0x5 idCpu=0x5 idApic=0xa iGipCpu=0x6 i64TSCDelta=0 enmState=3 u64CpuHz=3000003595(*) cErrors=0
00:00:03.864888 TM: GIP - CPU: iCpuSet=0x6 idCpu=0x6 idApic=0xc iGipCpu=0x7 i64TSCDelta=0 enmState=3 u64CpuHz=3000003675(*) cErrors=0
00:00:03.864891 TM: GIP - CPU: iCpuSet=0x7 idCpu=0x7 idApic=0xe iGipCpu=0x1 i64TSCDelta=0 enmState=3 u64CpuHz=2999994814(*) cErrors=0
00:00:03.864902 TM:     cTSCTicksPerSecond=3 000 003 765 (0xb2d06cb5) enmTSCMode=1 (VirtTSCEmulated)
00:00:03.864903 TM: cTSCTicksPerSecondHost=3 000 003 765 (0xb2d06cb5)
00:00:03.864904 TM: TSCTiedToExecution=false TSCNotTiedToHalt=false
00:00:03.865535 EMR3Init: fIemExecutesAll=false fGuruOnTripleFault=true
00:00:03.865973 IEM: TargetCpu=CURRENT, Microarch=Intel_Core7_WhiskeyLake aidxTargetCpuEflFlavour={1,0}
00:00:03.866591 GIM: Using provider 'KVM' (Implementation version: 0)
00:00:03.866597 CPUM: SetGuestCpuIdFeature: Enabled Hypervisor Present bit
00:00:03.866614 GCM: Initialized (fixer bits: 0x0)
00:00:03.866651 AIOMgr: Default manager type is 'Async'
00:00:03.866654 AIOMgr: Default file backend is 'NonBuffered'
00:00:03.866679 BlkCache: Cache successfully initialized. Cache size is 5242880 bytes
00:00:03.866682 BlkCache: Cache commit interval is 10000 ms
00:00:03.866684 BlkCache: Cache commit threshold is 2621440 bytes
00:00:04.677085 SUP: seg #0: R   0x00000000 LB 0x00001000
00:00:04.677093 SUP: seg #1: R X 0x00001000 LB 0x0002b000
00:00:04.677095 SUP: seg #2: R   0x0002c000 LB 0x00011000
00:00:04.677097 SUP: seg #3: RW  0x0003d000 LB 0x00001000
00:00:04.677099 SUP: seg #4: R   0x0003e000 LB 0x00003000
00:00:04.677101 SUP: seg #5: RW  0x00041000 LB 0x00001000
00:00:04.677103 SUP: seg #6: R   0x00042000 LB 0x00001000
00:00:04.677105 SUP: seg #7: R X 0x00043000 LB 0x00001000
00:00:04.677107 SUP: seg #8: R   0x00044000 LB 0x00002000
00:00:04.677171 SUP: Loaded VBoxDDR0.r0 (C:\Program Files\Oracle\VirtualBox/VBoxDDR0.r0) at 0xXXXXXXXXXXXXXXXX - ModuleInit at XXXXXXXXXXXXXXXX and ModuleTerm at XXXXXXXXXXXXXXXX using the native ring-0 loader
00:00:04.677174 SUP: windbg> .reload /f C:\Program Files\Oracle\VirtualBox/VBoxDDR0.r0=0xXXXXXXXXXXXXXXXX
00:00:04.677357 Opening the UEFI variable store 'E:\HASS\HASS\HASS.nvram' failed with VERR_VFS_UNSUPPORTED_FORMAT: Firmware volume length exceeds size of backing storage (truncated file?)
00:00:04.677371 VMSetError: D:\tinderbox\win-7.0\src\VBox\Main\src-all\NvramStoreImpl.cpp(1587) int __cdecl NvramStore::i_drvConstruct(struct PDMDRVINS *,struct CFGMNODE *,unsigned int); rc=VERR_VFS_UNSUPPORTED_FORMAT
00:00:04.677372 VMSetError: Failed to load the NVRAM store from the file
00:00:04.677389 VMSetError: D:\tinderbox\win-7.0\src\VBox\Devices\EFI\DevEFI.cpp(1667) int __cdecl efiConstruct(struct PDMDEVINSR3 *,int,struct CFGMNODE *); rc=VERR_VFS_UNSUPPORTED_FORMAT
00:00:04.677390 VMSetError: Can't attach Nvram Storage driver
00:00:04.677393 PDM: Failed to construct 'efi'/0! VERR_VFS_UNSUPPORTED_FORMAT (-24803) - Unsupported file system format.
00:00:04.677632 GIM: KVM: Resetting MSRs
00:00:04.677694 vmmR3LogFlusher: Terminating (VERR_OBJECT_DESTROYED)
00:00:04.856303 ERROR [COM]: aRC=E_FAIL (0x80004005) aIID={6ac83d89-6ee7-4e33-8ae6-b257b2e81be8} aComponent={ConsoleWrap} aText={Failed to load the NVRAM store from the file (VERR_VFS_UNSUPPORTED_FORMAT).
00:00:04.856313 Can't attach Nvram Storage driver (VERR_VFS_UNSUPPORTED_FORMAT)}, preserve=false aResultDetail=-24803
00:00:04.856435 Console: Machine state changed to 'PoweredOff'
00:00:04.949880 Power up failed (vrc=VERR_VFS_UNSUPPORTED_FORMAT, hrc=E_FAIL (0X80004005))
00:00:04.952668 GUI: UIMachineViewNormal::resendSizeHint: Restoring guest size-hint for screen 0 to 800x600
00:00:04.952700 ERROR [COM]: aRC=E_ACCESSDENIED (0x80070005) aIID={4680b2de-8690-11e9-b83d-5719e53cf1de} aComponent={DisplayWrap} aText={The console is not powered up (Display::setVideoModeHint)}, preserve=false aResultDetail=0
00:00:04.952816 GUI: Aborting startup due to power up progress issue detected...
00:00:04.962345 GUI: UICommon: Handling aboutToQuit request..
00:00:05.680472 GUI: UICommon: aboutToQuit request handled!
Failed to start the virtual machine HASS.
Can't attach Nvram Storage driver (VERR_VFS_UNSUPPORTED_FORMAT).
Result Code:E_FAIL (0X80004005)
Component:ConsoleWrap
Interface:IConsole {6ac83d89-6ee7-4e33-8ae6-b257b2e81be8}
