Hello, noob question.
I need to run a PHP script to get/send data to home airconditioner.
How to do this?
I see “shell_command” but hass.io doesn’t have a php commad line onboard.
Any help?
Thanks,
tode
convert your php script to a bash script?
PHP isn’t installed and shouldn’t be.
Thank you flamingm0e, but I can’t because the script makes ssl websocket connections and handles XML data. Too difficult, I think, to convert it into a bash script.
Maybe I can convert it into a REST service and install it on another linux server; then access it by HA rest_client…
Other solutions I’m missing?
tode
You can use python
Anyone find the solution to run php script in hass?
Is there addon for hassio?
convert to a supported scripting language.
python or bash would be best.
Is there a php to python converter?
I highly doubt it.
If you dont need any fancy php extension, just google for a precompiled static arm php binary, scp it to your hassio, make it executable and you can use now your php scripts.
do you have a link to an amd64 version?
apk add php8=8.0.8-r0
this worked for me
Run this command via ssh using any SSH addon
