hi,
Iβm trying to setup a docker image with hass on my rpi
In order to get de nefit plugin to work, I need to run in de python env:
pip install nefit-client
How can I do this in the docker image???
regards Richard
hi,
regards Richard
Build HA docker image that includes it. Then create container with that image
If possible, you can also run nefit plugin in a separate docker container and connect to that to HA
Is there a default manual/instructiions how to create a docker for hass?? So that I can do an extra pip install nefit-client
regards Richard
See the dockerfile here: https://hub.docker.com/r/homeassistant/home-assistant/~/dockerfile/. To install additional packages just append them onto the end of the pip3 install like so:
RUN pip3 install --no-cache-dir -r requirements_all.txt && \
pip3 install --no-cache-dir mysqlclient psycopg2 uvloop cchardet cython netfit-client
in docker hass you can only install APK
You should be able to create a new image by creating a Dockerfile containing
FROM homeassistant/home-assistant
RUN pip install nefit-client
and then run
docker build -t my_ha:0.68.1 .
But I just tried it and nefit-client seems to need more dependencies installing, so I didnβt follow on further.
I think it should be pip3 install nefit-client,
Collecting nefit-client
Downloading https://www.piwheels.hostedpi.com/simple/nefit-client/nefit_client 1 -0.2.2-py3-none-any.whl
Collecting pyaes (from nefit-client)
Downloading https://www.piwheels.hostedpi.com/simple/pyaes/pyaes-1.6.1-py3-non 1 e-any.whl
Collecting sleekxmpp (from nefit-client)
Downloading https://www.piwheels.hostedpi.com/simple/sleekxmpp/sleekxmpp-1.3.3 1 -py3-none-any.whl (434kB)
100% |ββββββββββββββββββββββββββββββββ| 440kB 636kB/s
Installing collected packages: pyaes, sleekxmpp, nefit-client
Successfully installed nefit-client-0.2.2 pyaes-1.6.1 sleekxmpp-1.3.3
If I want to change de dockerfile
Can I put it localy on my rpi and run the install docker command, but can I tell it to use de local dockerfile with an option?
docker run -d --name=βhome-assistantβ -v /path/to/your/config:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/raspberrypi3-homeassistant:0.68.1
Iβve got it working in HassIO using the following procedure:
Enable SSH access as described in https://developers.home-assistant.io/docs/en/hassio_debugging.html
Then SSH to hassio.local
ssh [email protected] -p 22222
#run shell in homeassistant docker containter
docker exec -it homeassistant /bin/bash
export PYTHONUSERBASE=/config/deps
#install pyaes
pip3 install --user --no-cache-dir --prefix= --no-dependencies pyaes
#install nefit-client 0.2.2
pip3 install --user --no-cache-dir --prefix= --no-dependencies nefit-client==0.2.2
