I have some python scripts in the python_scripts directory. I need no input into the script, only to run it from automation. Does somebody have an example for it? If i run them from commandline they work, so i only need an automation config.
Thnx for the support!
Here is one of mine, hope that helps:
- id: refresh vncsnapshot
- platform: homeassistant
event: start
- service: python_script.refresh_vncsnapshot
Thanks for the reply! when i paste your code it works. My code is the following:
- alias: 'Last payouts'
hide_entity: true
platform: event
event_type: telegram_command
event_data:
command: '/status'
- service: python_script.bittrex-minerpayment
I have this already working for reply messages for other commands from telegram. But now when i check the config i get the following:
Invalid config for [automation]: Service python_script.bittrex-minerpayment does not match format <domain>.<name> for dictionary value @ data['action'][0]['service']. Got None. (See /config/configuration.yaml, line 197). Please check the docs at https://home-assistant.io/components/automation/
Try changing the dash to an underscore in the name of your python script and see if that works.
Thanks for fast reply! this was the trick to accept the configuration.
The script is in the folder: config/python_scripts
I get the error below, is this the correct location? Also changed the automation line to python_scripts but same error
2019-04-17 20:53:17 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.automation_4. Service not found for call_service at pos 1: (ServiceNotFound(...), 'Service python_script.bittrex_minerpayments not found')
Did you try restarting HA after the change in script file name?
Yes i restartes ha
