Run Script (or Fire Event) when Opening Lovelace View
I’m looking to obtain thermostat information automatically when opening a view in Home Assistant Lovelace. The thermostat data is accessible via a script and I’ve setup the script entity with a “RUN” button so I can run the script manually from Lovelace. Now I’d like to run the script automatically when the view opens so I can see the latest thermostat information without having to click the “RUN” button.
I’ve searched wide and far with no success. Any ideas are appreciated.
Maybe by triggering on the sensor path attribute using browser mod?
Thanks for the suggestion. I managed to get this to work after installing and configuring browser_mod.
automation:
  - alias: "Open Browser"  # get the thermostat data when home assistant "thermostats" view is opened
    mode: single
#    variables:  # can't get these to work
#      browsers:
#        - sensor.roy_mac_safari
#        - sensor.roy_ipad_safari
#        - sensor.roy_iphone_safari
#      view: "/lovelace/thermostats"
      - platform: state  # in home assistant; switched to "thermostats" lovelace view
        # entity_id: "{{ browsers }}"  # can't get this to work
        entity_id:
        attribute: path
        to: "/lovelace/thermostats"
      - platform: state  # opened home assistant in "thermostats" lovelace view (uses condition)
        entity_id:
        to: '1'
    condition:
    - condition: template
      value_template: "{{ trigger.to_state.attributes.path == '/lovelace/thermostats' }}"
      - alias: "Get Thermostats"
        service: script.turn_on
          entity_id:
            - script.thermostats_get
One downside is that I need to manage the browser_mod sensors for each browser.
I wasn’t able to get the variables to work which would have reduced the redundant entities.
I discovered a better (for me) way to do this using App Events. It will fire an event when the Home Assistant iOS App becomes active. (There is an Android event_type too). This doesn’t fire when opening Home Assistant via a browser.
automation:
  - alias: "HA App Became Active"  # get the thermostat data when home assistant is opened
    mode: single
      - platform: event
        event_type: ios.became_active
    condition:
          entity_id:
Thanks! This works great for iOS, but what Android event type did you refer? There seems to be no android equivalent.
Did you find an equivalent?
No. There is none. You have to resort to more hacky solutions for android.
I think a simple way might be creating a webhook in HA and then using a (hidden) image in UI that will trigger the webhook via GET method when UI is loaded.
Have anyone managed to find a event or equivalent for when you open homeassistant on a computer/browser?
I’m looking into running a automation that requests updates for my Tesla but since they are only giving us 10$/month i only need to get updates when i actually open HA, either on phone or in a browser…
I’ve found ios.became_active to be OK for our phones but nothing equivalent for browser…
