/run/systemd-journal-gatewayd.sock: Are you trying to mount a directory onto a file (or vice-versa)?
Hey everyone,
i have recently installed HAOS on my pi and everything worked pretty good.
But today I restarted the pi and the homeassistant_supervisor container could not be started because of the following error:
Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting "/run/systemd-journal-gatewayd.sock" to rootfs at "/run/systemd-journal-gatewayd.sock": mount /run/systemd-journal-gatewayd.sock:/run/systemd-journal-gatewayd.sock (via /proc/self/fd/6), flags: 0x5000: not a directory: unknown: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type
I am thankful for any help you can provide me!
did you solve it? same issue here since today.
