I have an automation to detect TV being turned on, turn the volume down to 10 and then open an app.
Right now I have an automation for each TV; I’m wanting to combine this into a single automation if possible.
I can’t just select the entities of all the TV’s in the below example, as then if any TV is turned on, all the other TV’s that are on, will suddenly trigger the automation.
This definitely seems doable. One way to go about this is to create a trigger for each device, and assign each one a unique trigger_id (in the UI click on the 3 dots top right of the trigger). Then you can use each trigger ID as a case in an if-then action.
Alernatively, maybe if you made each trigger_id the same as each devce_id, you could just use a template trigger variable as your device target. For example:
