Will this issue be addressed in a not too distant future release?
I was told by a dev that Hassio does not include the exec command that is needed to take advantage of this flaw, but it will be patched regardless.
Already fixed in most Ubuntu-based systems using docker and runc.
https://people.canonical.com/~ubuntu-security/cve/2019/CVE-2019-5736.html
If you have Unattended Upgrades enabled (the default is Enabled since 16.04), then you likely have the fix already.
